Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-28-2007, 11:23 AM
mollyzoe mollyzoe is offline
96 GM Squeeking front end Help!!!
Our 96 GM I just bought is now squeeking when I turn the sterring wheel and when I go over a sudden bump . I found that it is coming from the front suspendtion on both sides and from the rubber bushings . Can I spray silacone on them ? What else can I do ?? Please help. Thanks. D
Old 03-28-2007, 05:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 96 GM Squeeking front end Help!!!
Spray away. Or change the control arms. Also check the ball joints to be sure they are not also a source of the squeak.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-28-2007, 06:00 PM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
My 98 was squeeking and it was really hard to find. I started drilling small holes in the ball joints and spraying lubricant in the holes. It finally stopped when I got to the left tie rod end.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 04-04-2007, 05:47 PM
Smile Re: 96 GM Squeeking front end Help!!!
I finally found the problem. The Idler Arm is Shot. It originally sounded like it could have been a worn out pully belt, but as my son turned the sterring wheel with the engine running, I saw and felt the idler arm with my hand and it was moving all over (up,down) the bushing was shot and causing the grinding noise all along. I bought a new one and it is made a little differant than the OEM one. The new one has grease fittings on it and it does'nt have the castle nut at the end of it where it comes down from the frame where the front part of it is mounted. Also ,the new one is twise as thick as the OEM idler arm was. I remember helping my son look for a GM or a Crown Vic and we found 2 cars with broken idler arms. This must be a common problem with them. Anyway thanks for your help. Dan in NJ.
