Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-10-2002, 04:20 AM
CustomWhips's Avatar
CustomWhips CustomWhips is offline
Send a message via AIM to CustomWhips
spring crisis
ok i got some tenzo lowering springs and had them put on my factory shocks. well i noticed when i was changing my break pads after i jacked up one side a side seemed to be higher like very noticably higher i measured and it was infact higher then the one side. so my question is this because i have my factory shocks?
also i got 2 and 1/4 drop springs well they didnt drop the car like i wanted. if i got new shocks for the springs i have would it drop it more?
also to me sometimes my car ride higher then somedays. this is not in my head it is infact riding higher somedays mainly one side or the other but sometimes the back is higher and what not. strange. any input?
alssssooo
when i bought my springs i got them from a punk ass motor sport shop. they realy dont care who you are they want the cash.. i bought springs for a 99 but on the box it only had like 94 through 97 well it wasnt intended for my car.. could this be the problem with the drop and how its not what i thought it would be?
Old 10-10-2002, 05:24 PM
thanks
mad help yo. appreciated. i guess this is why i dont post in this particular forum..
Old 10-11-2002, 12:04 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: spring crisis
alssssooo
Well the most important thing is are you measuring it on a level FLAT surface? Like a garage? Or are you doing it on your driveway where it might not be so flat?
In some cases the springs should be the same length. but when installed on a car each corner might weigh different from either left to right. Measure from the wheel well to the ground to get somewhat a correct measurement.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-11-2002, 03:18 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Just a general FYI, the driver's side of your car will generally (in a Civic at least) sit a tad lower than the passenger side. I've noticed this with my car too, as have other people I know. I dunno if this is because most of the engine weight is on this side of the car or what, but like CivicSiRacer said, each corner of your car can have an impact on this. That's why adjustable coilovers are best, because they allow you to corner weight your car where each is balanced evenly.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 10-11-2002, 06:10 PM
delsolsi delsolsi is offline
Also after jacking up your car give the springs a chance to settle before you measure.
Old 10-13-2002, 10:31 PM
æ
it was level .. but SilverY2KCivic 99 and 00 are like exact. and you described it perfect.
fuckn crap now i gotta spring for some coil overs.
Old 10-14-2002, 07:32 AM
Civic Mod
Re: æ
You don't have to. Some shops might be able to add a spacer between the spring and the shock collar to level it better (if it annoys you that much). You could also try moving the battery or adding a small spring spacer between the coils.
Autocross Help Page
Buy my Civic parts!
Springs Made in Canada springman West Canada 0 12-01-2010 04:14 PM
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 09:25 PM
Lowering Spring HELP! sentoyang Brakes and Suspension 2 10-23-2009 05:34 PM
Prizm 2001 LSi Suspension Coil Springs genti Prism 0 04-16-2009 02:48 PM
Detachable Spring under front seat adamchrissy Type 1 1 03-14-2009 10:58 PM
