Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-23-2007, 07:22 AM
guido0136 guido0136 is offline
Looking for new wheels and rims
Hello all: I'm looking at geting new rubber for my 1993 Transsport. Currently I only have the standard rims with the stock hubcaps. I have noticed on different makes (Lumina APV) and different years of Transsports some nice stock and not stock rims. I'm hoping to make my van look a little more sporty.
Can any 1990 - 1996 Transport or Lumina APV rims be interchangable? Also, has any one purchased non stock rims and if so what sizes am I looking at and does any 1 have any pics?
Thanks in advance.
Old 03-23-2007, 11:27 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Looking for new wheels and rims
You could check out tirerack.com for info on the rims, and you could get info from a Hollander interchange manual on the interchangability of the rims from various models/years. Many salvage yards still use these, and you could try calling some of them and ask about the interchange, and if they may have some different rims.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-28-2007, 05:56 PM
Jeffrv's Avatar
Jeffrv Jeffrv is offline
I believe all those years will fit. I have a 1995 trans sport and used 15 inch steel rims off a Grand Prix or Bonneville to mount winter tires on, using stock tire size. I think just about all 15 inch 5 bolt rims, FWD, of the 105 or 100 MM bolt pattern diameter ( not sure what they are) will probably fit, just be careful of the offset
Old 03-29-2007, 03:38 PM
nicke66 nicke66 is offline
Re: Trans Sport 1990-1996 size of rims
All year 1990-1996 (and also later year) have rims of size:
size: 15x6" bolt pattern: 5x114,3 mm offset (ET): 35 mm bore: 70.3 mm
I think first two year did have 14" for some models. As you said, most rims from FWD GM cars of this years does fit the Trans Sport.
A useful web link:
http://www.discountedwheelwarehouse...._Reference.cfm
