Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-20-2007, 09:50 AM
FVM FVM is offline
4L60E No Reverse Bulletin
Has GM ever recalled this 4L60E for repair of the "No Reverse" issue? Through Net searching I found this problem has occured since day 1, 1994.
IF not are there enough customers to issue an ultimatum to GM to repair there trans free of charge, since this is a known OEM failure.
I'm amaized, all I did was make a normal left turn forward & the trans went out.
Old 03-20-2007, 12:20 PM
maxwedge maxwedge is offline
A990 racer
Re: 4L60E No Reverse Bulletin
Welcome to AF. The component responsible for those failures have been strengthened and updated around 2001, good article in the latest Hot Rod addressing this.
Old 03-20-2007, 12:29 PM
Blue Bowtie's Avatar
Registered Offender
If you think you have lost the hub for the reaction sun shell, you can see exactly what's involved:
4L60-E Repairs
Old 03-31-2007, 09:22 AM
comp comp is offline
4L60-E Repairs
good link
Old 03-31-2007, 04:46 PM
FVM FVM is offline
THANKS ALL:
Trans is rebuilt. Found the USUAL Sun gear stripped out. Luckily I didn't force it to get home otherwise there'd been more damage.
Just not sure why GM hasn't been sued big time for this, I've found that "high TENS of thousands" of customers have had this one part go out. It's little wonder why GM is having financial difficulties, I'm not interested in buying GM again... unless they can pay back this trans cost loss. Doubt it though.
Odd thing, I got a GM Warrentee Extention application... 3 days after the it had expired. Heard GM does this also on a regular basis, they send the notice ON or the DAY before it's due, just to get the postmark validated.
Again thanks all.
Old 04-01-2007, 10:26 PM
Registered Offender
That has been a failure point of the TH700-R4/4L60/4L60-E since the '80s. It has happened to tens of thousands, but compared to the ten of millions of those transmissions in use, the percentage is relatively small. The sad part is that it has been a known weak point for years and although maybe only a half of a percent of them fail that way, the numbers are high due to the market penetration.
If you think that's bad, check out the problems on some of the transmissions which HAVE been forced into recall or settlement, like the Chrysler "Golden Shaft" FWD automatics, or the Subaru, Mitsubishi, and Ford FMX transmissions for example.
The other known weak points are the 3-4 clutch, the input planetary, and the pump bushings which tend to take a lot of wear from the converter.
Old 04-02-2007, 10:42 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
It even happens to the best of us!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-24-2007, 12:05 AM
tabernacle tranz tabernacle tranz is offline
Post Re: 4L60E No Reverse Bulletin
WELL NO REVERSE AND 3-4-CLUCH PROBLEMS HAVE BEEN FOLLOWING THIS TRANS AROUND FOR YEAR'S ..WHEN THE FIRST 700R4 TO THE 4L60E THE SHELL BROKE, I REPLACED LOT'SSS OF THEM BUT IT CAN BE FIXED AN AFTERMARKED CO, MADE WHAT THAY CALL THE BEAST AND IT WORK'S. YA THAY SAY IN 2001 THAT THE PROBLEM WAS FIXED NOW THAY DON'T BRAKE , NOOOO NOW THAY STRIP THE SPLINES OUT . I INSTALL THE BEAST IN EVERY 700-4L60-4L60E I REBUILD GOOD OR NOT BECAUSE I NO IT WILL BRAKE !!!!!! SO THE NEXT TIME YOU HAVE NO BACK-ER-UP-ERS TELL THE TRANY SHOP TO INSTALL THE BEAST AND THE 3-4 CLUTCH PROBLEM WELL THATS ANOTHER STORY
Old 07-24-2007, 06:57 AM
is that a HP part ? what company ?
Old 07-25-2007, 12:24 AM
Bootsgamer's Avatar
Bootsgamer Bootsgamer is offline
Send a message via AIM to Bootsgamer
Well now when somone asks you if you have ever had any problems with it you can say yeah i did too.
Team Unknown
My racing team
myspace.com/racewiththebest
Old 07-25-2007, 12:33 AM
TCI Auto: 4L60E/700-R4 Beast Sunshell 82-later here is a link check it out and yes it is HP but installs like O E M, i installed it in my 95 S10 383 stroker with 714HP at the weels and never broke. you can get the same part from www.axiom.com cheeper so try it and good luck
Old 07-25-2007, 03:03 PM
silicon212's Avatar
Confoundingly Lucid
$108 is a bit high - you should be able to get this for around $60. It's made by SPX/Filtran, but marketed also by TCi. If you have a 700R4, 4L60, 4L60E or 4L65E, then it is most definitely a recommended upgrade part for all.
Old 07-26-2007, 09:38 PM
Registered Offender
More like $44 a couple months ago. They are now made in China (that is not meant to be a joke - They are made in China).
