Old 03-17-2007, 04:53 PM
03impala9c1 03impala9c1 is offline
automoter gauges
so i picked up an electric oil pressure gauge and mechanical boost gauge and a/f ratio gauge. I was wondering where can i install the new oil pressure sending unit... which wire i tap into for the air fuel ratio gauge... and which vacuum line i need to tap into for my boost?
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 03-17-2007, 07:10 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: automoter gauges
I believe it will be the purple wire from the Bank 1, Sensor 1 (front) O2 sensor which is the H02S Hi line.
For boost gauge you tap into the vacuum line for the MAP (manifold absolute pressure) sensor. You should see the vacuum line that runs under the front (snout) part of the supercharger.
Timeslip 08/12/06
AF Community Guidelines
