Old 03-10-2007, 02:42 PM
03impala9c1 03impala9c1 is offline
Cruise Control Problem in 98 GTP
So when i bought the car the cruise control didnt work... No cruise light on the dash or anything.
I replaced the lever and the cruise control brain...The yellow cloth band inside was frayed and broken on my old one.
Yet no cruise control.. No indicator light.. nothing.
The lever was used off of a 98 GP supposedly and when installing it... i did notice a wire or 2 was different on the harness than the old one.. But everything else still works! HELP im going on a road trip on the 18th and desperately want cruise.
Thanks
Jeremy
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 03-10-2007, 08:52 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Cruise Control Problem in 98 GTP
It is common to have different color wire color coding on parts like the multifunction (MFS) switch. Have you checked the fuses for cruise control and measured for 12 volts at the fuse sockets?
Timeslip 08/12/06
AF Community Guidelines
Old 03-11-2007, 09:12 PM
fuse is ok have to borrow a voltmeter to check for 12V supply.
Old 03-12-2007, 03:15 PM
Q-Ball23 Q-Ball23 is offline
Check your vacuum lines. Mine doesnt work cause my lines bursted.
1992 Grand Prix SE @ Stock
Old 03-12-2007, 03:24 PM
BNaylor's Avatar
Big problem with that advice. The cruise control system on '97 and up Grand Prix is not vacuum controlled. There is no vacuum actuator. It is electronic only.
Timeslip 08/12/06
Old 03-12-2007, 05:44 PM
Hmm really. I was planning to swap out my 3.1 MPFI to a L67 3800 Series 2 or 3. And I was told it shouldnt be problem to rig up cruise control. Thinking that I thought they were the same.
