Old 10-07-2002, 10:24 AM
xxdcmast xxdcmast is offline
Question
I've seen a few piston sets for cavaliers and the come in all different compression ratios. I think that the higher compression ones give you more horsepower? but im not really sure. Will an engine wioth 11:1 compression have more horsepower than one with 9:1 compression. Also I have heard you cant run 11:1 compression with a super or turbo charger is this true? What is the best course of action for incresing my hp low or high compression.
xxdcmast
Old 10-08-2002, 04:18 AM
TRDcavalier__O TRDcavalier__O is offline
Banned
blowing up your motor
Yea you can run 11:1 with a SC or turbo but your motor will die soon after. What kind of car do you have? I have the 2.4. it currently has a 9:5 compression ratio. 9:5 is not too high if your gonna run low boost, but you should build your engine to suit your application. If you are gonna put a turbo in it and are planning on running high boost levels then you wanna lower the compression. I suggest you get block sleeves if your gonna run high boost. I myself am planning on getting a SC and i plan on running high boost, but the boost i will get out the super charger will not be too much too have to lower the compression. If you own a cavy your best bet is to get the GM super charger. unless you wanna build a one time down the track motor then you can throw in 13:1 and 20psi lol and sure it will be real fuckin fast but not for long.
Old 10-08-2002, 08:37 AM
I have a 2000 2.2 liter I was thinking of goin up to either the 2.2 ecotec or the 2.4. Im probly gonna stay mostly with NA and was thinking of maybe 11.5:1 compression higher if possible. I just wanted to know if I could throw a low boost turbo or supercharger on the engine without blowing it up maybe 4-6 lb. I just wanna know what the limits are before i see a piston come flying through my hood.
Old 10-08-2002, 10:24 AM
DeViL DeViL is offline
If you went with an 11:1 compression ratio wouldn't you have to use some sort of high octane additive to your gas?
'01 S-10 Xtreme - Supercharged 4.3L V6, 10 psi.
'88 Firebird Trans Am GTA - 5.7L V8, 4spd auto.
'06 GTO Brazen Orange Metallic - 6.0L V8, 6spd (the new toy/daily driver)
Old 10-08-2002, 09:09 PM
71Shark's Avatar
71Shark 71Shark is offline
Re: .
93 octane should be fine, the computer should be able to handle it. Vettes with the LT5 had 11:1 compression from 90-95 and run on 93.
Questions,Questions,Questions.... r_c_inicial Mustang Talk 11 08-23-2005 08:26 PM
Questions Questions and more Questions H22silverbullet Prelude 15 07-30-2005 07:23 PM
Question Question Question Integra14 Car Modeling 2 12-07-2002 08:31 AM
