Old 10-06-2002, 05:23 PM
1990civic's Avatar
1990civic 1990civic is offline
PROB WITH MY REBUILT Engine
Well I Just Put My Rebuilt 1.5 L Engine Back In The Car (Nothing Performance, For Reliability), Anyway I Checked Everything, Went To Start The Car And Everything Is Fine, But Im Getting No SPARK!! So I Swapped The Distributer From My Sisters Car Of The Same Year And Model, But Still Nothing (Sisters Distrubuter Works Fine)!! What Should I Do The Car Turns Over, But I Just Dont Get Any Spark, Also I Checked The Wire's Going To The Distributer, And They Have Power Going To Them!! What Should I Do??? ALSO Please Only Post If You Have Extensive Knowledge On Honda Engines!!
Old 10-07-2002, 09:33 AM
kaytec4door kaytec4door is offline
well man no spark sucks but i have a couple of things to try. first all us mechanics when dealing with electricity start off by doing a method called th k.i.s.s. method. (keep it simple stupid) i would go and double check every wire. especialy a white and blue wire that goes to the distributer. that was the problem on my friends motor after i did his swap. second check all of ur grounds like the one from the valve cover to the frame, and third i would check my connections to the ECU. well good luck man
2005 Hybrid with recurrent engine/IMA lights SheltieMan '01-'05 Civic 1 07-14-2010 08:54 AM
I need help A.S.A.P with my engine jstevens1978 General Discussion 3 07-21-2009 02:54 PM
anybody experiencing problems with no oil pressure at idle - new rebuilt engine? pehi Intrepid 1 07-28-2004 05:42 PM
cars with rebuilt engine good? dave99 Car Buying Q&A 1 08-07-2003 05:58 PM
$1200 for a 91 trecel with rebuilt engine question Melt Tercel 5 06-26-2003 07:35 PM
