Old 03-03-2007, 01:28 PM
03impala9c1 03impala9c1 is offline
Exclamation steering wheel radio control installation
so my switches took a crap the other day and i got new ones off ebay. pulling the old ones out was pain enough because the wires are too short connecting to the switches but how do i get the new ones in??? i cant get anything between the switch and the steering wheen to slip the harness into the switch do i have to take apart the steering wheel???
Need help!
thanks
jeremy
Old 03-04-2007, 10:34 PM
Re: steering wheel radio control installation
WELL... I FIGURED IT out by myself... in case anyone here needs to know... heres how to change them...
1. wiggle out old switches.
2.pull and disconnect old switch.
3. unscrew rear cover plate of steering wheel (2 torx head screws).
4. pry lower part of plastic back.
5. Locate a black wire that runs around the wheel from the hole where the switches were located and runs to the bottom of the steering wheel.
6. There is a hook that holds the wire onto the corner eof the steering wheel.
7. pull the wire loose from around this hook.
8. pull the wire harness outward out of the hole in the wheel.
9. plug in new switch.
10. take an allen wrench or something of the sort and pull the wire back through the hole and wrap the wire back over the hook.
11. push new switch back in... test... and tighten the rear wheel cover back on and your finished!
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 03-05-2007, 11:38 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Thanks 03Impala, I've been watching this thread hoping someone would chime in.
Old 03-05-2007, 12:48 PM
guitarfish's Avatar
guitarfish guitarfish is offline
Good job on the repair. I did it on a '94 GP, you had to remove the airbag to do it.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
1994 GP SE - 231,000
1997 GP GT - 134,000
1998 GP GT - 225,000
2002 GP GT - 222,000
Old 03-08-2007, 11:19 AM
BNaylor's Avatar
BNaylor BNaylor is offline
How about posting your procedure at our Tips & Maintenance forum. See link below. Pics would be helpful but not necessary. Thanks.
Click here
Timeslip 08/12/06
AF Community Guidelines
