Old 03-02-2007, 08:48 AM
beck-key beck-key is offline
03 Monte Calro SS - Traction Control/ABS
I have a Monte Carlo 03.The Service Traction light keeps coming on, along with the abs light. I can't seem to find out what the problem is. I've checked the brakes. Checked all the fluids.The rotars look good.I Checked it with a computer. The abs/Service Traction system still comes on. The traction off button had something spilled on it at one time.Could that be it? Help?
Last edited by beck-key; 03-02-2007 at 10:49 AM. Reason: I was'nt sure if I was getting my problem accross
Old 03-02-2007, 09:43 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: 03 Monte Calro SS - Traction Control/ABS
whats the problem? You've told us what you've done, but not what the problem is.
Dragging people kicking and screaming into the enlightenment.
Old 03-02-2007, 05:29 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
the light's on, but he doesn't know why.
Seatbelts Saved My Life
Old 03-02-2007, 11:38 PM
UncleBob UncleBob is offline
AF -Advisor
if the lights are on, that means there is a code. When both the traction and ABS lights come on, thats usually a sign of a problem with a sensor or input that is needed for both systems.
Whoever "checked the computer" needs to look more closely
this may or may not be the problem but there is a TSB (Bulletin No.: 03-05-25-008) for your car that has to do with the front wheel speed sensors having badly routed wires causing the lights to come on. The fix is to replace both front hub bearings, which have the speed sensors mounted internally and are integral.
You would want to verify if your car falls within this TSB, and also verify that the sensor harness' are actually the problem
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
