Old 03-01-2007, 09:43 AM
jcurry05 jcurry05 is offline
Exhaust resistor
Is there any downside to removing the resistor from a GP exhaust? I have been told that there will be no problems but I can't help but think it was put there for a reason. I was told it just makes the exhaust note quieter. Will it make some unGodly sound inside of my car? Thanks
Old 03-01-2007, 09:50 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Exhaust resistor
You mean resonator?
Timeslip 08/12/06
AF Community Guidelines
Old 03-01-2007, 09:53 AM
Originally Posted by bnaylor
You mean resonator?
Yeah thats what I mean Sorry.
Old 03-01-2007, 04:44 PM
wethepplebmxer wethepplebmxer is offline
just ,makes it louder...
The GTP's Kill list:
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- 90ish Prelude (modded)
- Eclipse GTS
- 03 or so Civic Si
- 96 Eclipse GS-T (some mods)
- 04 WRX (manuel)
- 94 Prelude V-tec (head, cat, more...)
- 06 WRX
- 96 T/A
- 05 300C
Mods: Thrasher CAI, 3.4 pulley, straight pipe (res and u-bend delete), ZZP PCM, Colder plugs, new wires, 180 t-stat.
Old 03-02-2007, 06:41 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Removing the resonator will make it louder inside the car and will not increase performance in any way. I suggest that you leave it on and just remove the u-bend if you haven't already done so. Sometimes removing the resonator actually makes the tone of the exhaust sound worse not better.
Old 03-02-2007, 07:19 AM
Do you have to replace the sensor when the u-bend is removed or does it just pop in and out?
Old 03-02-2007, 08:32 AM
BNaylor's Avatar
The rear 02 sensor is threaded into a bung so it doesn't simply pop in and out. There is one electrical connector to it. Unless you are havings problems with it just re-use it. The u-bend delete pipe must have a bung installed or you will not be able to mount the sensor. The sensor monitors CAT convertor efficiency. In lieu of the sensor you can use an 02 simulator or a DTC such as P0420 will set and trigger a SES/CEL light. See pic below.
Timeslip 08/12/06
