| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
what do you do if you put jp8 in a car?
I let A friend borrow my car and he put jet fuel (jp8) in the tank (5 gallons) , dont ask me how or why but he did. what is the best advice for getting it out and not totally destroying the car. Should i just fill it up and mix it with regualr fuel to try to dilute it? Or should i just drop the tank and flush the fuel system? Hopfully one of you guys can help me out.
The Car Illiterate Guy |
Re: what do you do if you put jp8 in a car?
hmmm. i dont think that it would destroy the car, but yeah, fill it with as much regular as you can to dilute it.
Siphon what you can out, or drain it if the tank has a drain bolt, THEN fill with regular fuel. 5 gallons is a good percentage of a tank.
true. i'm used to a 26 gallon tank.
still, isnt jet fuel just better quality gas?
i mean, it might have insane octane (or equivalent) but would it really do damage? |
I thought jet fuel was around kerosene..
EDIT: I know someone who ran 100% kerosene(only 1 tank full) in a 90cc 4-wheeler. It ran a long, happy life..
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
but kerosene is used as an additave in engines.
Kerosene is very close to diesel, not used as an additive in gasoline, and should be removed. It won't do much damage, but it won't run if its a gas engine.
If its a diesel engine, dilute it with as much diesel as you can and run it, then change the filter after that tank.
Dragging people kicking and screaming into the enlightenment. |
^ and if it does manage to run (ive seen it happen) it'll make so much smoke that you'd be pulled over in a heartbeat.
i cannot find the article online, but Car and Driver did an article on the '51 buick lesabre concept. the one designed by harley earl.
it used kerosene injection as a performance enhancement at i think 75% or greater throttle. unless i am mistaken on it using kerosene that is. |
it might have been propane now that think about it...
AV-GAS is high octane for piston engines, jet fuel is close to diesel with all the waxy stuff removed. |
This sounds a lot like the guy that said his friend put that flush stuff in the engine that was bad for it, didn't want to tell his father, but no one actually believed him. Is it easy to get jet fuel??
Sorry to be the naysayer..but jet fuel?
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
and most likely your friend is just bull shitting you.
67 chevy c 10 needs paint 01 mustang gt needs hp |
unless you work at an airport and are figuring that you can kill two birds with one stone |
