Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-04-2002, 10:21 AM
f20bheaven f20bheaven is offline
Send a message via AIM to f20bheaven Send a message via Yahoo to f20bheaven
Question no fuel in 87 RX!!!
okay I bought a 2nd Gen RX-7 for $300 from a friend of mine..it has been sitting for about 3 years...I thought I could get it started and I have a new turbo 13B on the way...well it is a convertable and the top has been leaking...anyway I have corrected a few problem and got it to turnover but. there is no power running to the fuel pump..the pump is fine the relay is fine and even the fuel sending circuit works...just no power...what could be the problem, I have no books or diagrams so please help me out!!!!! thanks.....
Old 10-04-2002, 10:52 AM
Kaneto's Avatar
Kaneto Kaneto is offline
Send a message via AIM to Kaneto
Grab the service manual from FC3S.org. It has the wiring diagrams.
First thing I'd do is grab a multimeter and check the voltages at the fuel pump and at the relay.
Oh, also... a lot of people install a switch to cut off the fuel pump in case of flooding. Could be possible that one was installed on your car and it's just switched off.
88 Mazda RX-7 Turbo II, 87 Mazda RX-7 base, 91 Honda CRX DX, 00 Honda Civic Hatchback
Old 11-27-2004, 05:26 PM
Racer JT Racer JT is offline
Any update?
I have the same problem and have tested the relay and it's working fine. But no power at the pump. 88 Turbo II. Can you just run a Hot wire with a switch direct to the pump????
Thanks,
Jesse
Old 11-27-2004, 05:30 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: no fuel in 87 RX!!!
Jumper your fuel pump connectors!!!!! If that works, then you have AFM problems! Very common in that year!
1988 10th AE Edition TII
More mods then you have.
Old 11-27-2004, 09:43 PM
more help
I jumped the pump off the battery and still got no run. When testing the voltage to the pump got zero, notta no juice at the wire to the pump, but also when jumped it, it did nothing??????? Any idea?
Mazdaspeed RX-7 GT-C Custom Hiryu Completed Projects / Gallery 5 06-13-2010 11:10 AM
Mazdaspeed RX-7 GT-C “Unicorn” Custom Hiryu WIP - Street 21 06-08-2010 12:31 PM
RX-300 taillights gobs1 RX300/RX330/Harrier 3 11-24-2009 09:08 PM
RX-7 Undercarriage Hiryu Car Modeling 2 10-11-2009 05:15 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
