Go Back   Automotive Forums Car Chat > Toyota > RX300/RX330/Harrier
Old 11-21-2009, 03:39 PM
gobs1 gobs1 is offline
RX-300 taillights
Taillight fuse blows, no lights is there a common problem w/ RX-300's? Everything is stock untouched I believe bought 1 month ago. It's a 1999.
Old 11-24-2009, 04:06 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: RX-300 taillights
Check if you have a wiring harness tucked in behind the rear bumper for trailering. If so, it may have a short in it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-24-2009, 07:59 PM
Gobs1 update: since you can't legally drive w/o taillights I took it to a short-circuit finder, cost $140. Turns out the Tygon tubing got clogged and the well next to the spare got filled w/ water this submerged the rear drivers side running light this submerging caused a meltdown of the light socket which caused the taillight fuse to blow. "There is no such thing as a free lunch."
Thank you Automotive Forum.
Question: What is the TYGON tubing for, what does it drain??
Old 11-24-2009, 10:08 PM
jdmccright's Avatar
The RustBuster
Well I'm not sure which part has the tubing, the light itself (usually a short 90° piece) or the well the light assembly fits into. But they both would serve a purpose. Obviously the one for the well helps drain water from that area which is probably not watertight. Over time I guess dust and sirt got washed down into that tube and clogged it...they may have opted to not use a rubber seal around the light for any number of reasons. Odd that it got so full the wiring shorted, but great to hear you found the problem.
FYI the light assembly probably has one too, to help prevent condensation and fogging up of the lens by allowing the air in as well as allow pressure to equalize when the air inside gets hot from the bulbs. Newer LED versions may not need this since they run at such a low power.
Congrats on finding your problem and welcome to AF!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Tags
1999 , blows , fuse , rx-300 , taillight
