Old 10-04-2002, 12:47 AM
mengy mengy is offline
So I took my Dizzy back to Autozone
and the guys tell me that the TDC/Crank Angle Sensor is not inside the dizzy... I tell them that I have a diagram that shows it clearly... then the guy said he'll just get a new one for me..... it'll be here tomorrow....
I'm right yes? the crank angle sensor is inside the dizzy right?
the new one better work!
Old 10-04-2002, 03:29 AM
91civicDXdude's Avatar
only if you get a distributor for a car that has the MPFI stock. DX motors do not have the CPS (cylinder position sensor) inside the distributor.
Old 10-04-2002, 01:01 PM
WTF? then why is my ecu throwing that code and limiting my RPM???? shoot something else must be wrong then.. so you're telling me that... since I only have dpfi my dizzy doesn't have the crank angle sensor inside?
cooling system back pressure, heater not working BrandonMurray Grand AM 4 04-27-2010 09:25 AM
Possible Exhaust Back pressure on 96 Olds Cutlass Supreme chrisluna Cutlass Series 4 10-16-2009 06:01 PM
Need to remove backseat side back rests on 2004 I35 tgneid Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-21-2009 06:15 PM
Took a break..Im back! weaponCIVIC Car Modeling 1 11-02-2005 06:49 PM
Some pics i took during Spa Francorshamps days 3 years back... christophe320d F1 11 12-17-2004 11:54 AM
