Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-22-2007, 04:47 PM
cjluis cjluis is offline
service engine soon light comming on
I have a 94 camaro and the service engine soon light comes on every once in awhile. I have noticed it usually only comes on if it is a bit warmer out side but not always. I have tried to get the obd to show the code but I have been very unsuccessful. I have tied a paper clip and a so called code key but nothing. Any other suggestions of how to get the code with out spending a ton of cash would be great. I think it might be the O2 sensor but not sure. The car also has about 137k on it.
Old 02-23-2007, 09:16 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: service engine soon light comming on
Paperclip will not work on your car, it's an OBDI hybrid (the inbetween phase in for OBD II) you need a compatable scanner to get the code.
Old 02-23-2007, 09:27 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Since you have the obd1 hybrid with the obd2 port, then Advance Discount (maybe some others, not sure on that) should be able to scan your codes for you. Of course they're going to ask you for the year of the car, and you say 1994, then they tell you they can't read it. But that's not true, their scanner reads both OBD1 and 2 systems, they just don't have the OBD1 connectors. But tell the person that you have an OBD1 system with the OBD2 style connector. But before they try to scan the codes, tell them go in and put the year make model and engine in on the scanner, then read the codes. Otherwise the scanner wont read any codes.
I hate how they don't train the people to use those things...
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 03-02-2007, 10:34 PM
bag91's Avatar
bag91 bag91 is offline
I bet its something stupid like your egr valve..........
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
