Old 02-20-2007, 05:09 PM
wilson4 wilson4 is offline
Question Car sounds! what is wrong with my engine?
ok so had this problem for a couple of months now, i hear a knocking or clattering sound when the car starts up cold, disapears when started warm or after warm up, i notice the sound get louder and sounds rougher when its really cold out (0-20 F ) and when i accelerate without letting car warm up a bit it sounds really loud. At first thought it might be knocking, however after i listened to it closely it sound more like vavles clattering.
Here are 2 sound clips (sorry for cars passing in background)
mic set on car hood, then after start up moved closer to grill
http://www.yousendit.com/download/MzZGMFhnUzh3TGg1VEE9PQ
hood opened and mic set next to engine (sound is hard to hear here, it disapears becuase engine was warm for first start-up) (how does engine sound otherwise?)
http://www.yousendit.com/download/MzZGMFhrQXBVVGw1VEE9PQ
first one is best indicator you can clearly hear sound
Thanks, john
Old 02-20-2007, 08:19 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Car sounds! what is wrong with my engine?
Sounds like a valve tick to me. Could also be piston slap.
What car, year, engine?
Dragging people kicking and screaming into the enlightenment.
Old 02-20-2007, 08:47 PM
1996 buick century 105,00 miles 3.1 v6
Old 02-21-2007, 01:03 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You have just described classic piston slap sounds
If this has come on relatively suddenly, its possible one piston has a collapsed skirt.
If you are lucky, you can locate the piston, pull the intake, head and oil pan, remove the offending piston, hone the cylinder and pop in a new piston.
You should be able to do all this without removing the engine. I have done just this on a Chevy 2.8 V6 (same engine family as yours) with complete success.
If the cylinder or engine wear is too great, its time for a rebuild.
Old 02-22-2007, 12:51 AM
UncleBob UncleBob is offline
AF -Advisor
the "fix" for the GM piston slap is to perform a "motorvac", which many shops can do. Roughly $150. Although I thought that was more of a problem with the new-style V8's such as the 4.8's and 5.3's
Either way, I agree it sounds like a top end noise. Could be valves or pistons slap. Need to narrow it down with a stethoscope
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 02-22-2007, 10:37 AM
Can a compression check confirm this?
Old 02-22-2007, 10:38 AM
