Old 02-16-2007, 12:23 PM
lcwt5884 lcwt5884 is offline
adding coolent to a 2000 pontiac grand prix?
im trying to put coolant in my car it says i have to first drain the cooling system then i need to flush it. i do not have a owners manual by any chance can some one walk me threw the steps
Old 02-16-2007, 07:49 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: adding coolent to a 2000 pontiac grand prix?
Welcome to AF.
The procedure will not be in the owner's manual. One of our members posted this guideline awhile back and it appears to work. See below.
Here is a basic coolant flush procedure:
Install the flush T from the Prestone Flush Kit in the heater return line hose.
1. With engine cool, remove radiator cap and drain the radiator.
a. Turn drain plug (lower left engine-side of radiator) counter clockwise about 1/8 of a turn (may require a little force if it's not been opened in awhile--be careful because it's plastic). Use the end of a 1/4" drive handle. Plug will extend slightly as it loosens. Be sure to have a container in-place to collect the antifreeze.
2. Let all the antifreeze drain into a container.
3. Remove, drain and clean the antifreeze overflow bottle. Reinstall bottle.
4. Hook up a garden hose to the flush T and turn water on (not too high or you can damage seals/gaskets with the pressure). When water starts to run from the drain plug, start the engine and turn the heater on (make sure you leave the water running during this process).
5. When water runs clear (about 5 - 10 minutes), turn off car, then turn off water, and remove hose from T and cap it. Let remaining water run from drain plug. (Note: Not all of water will be drained out of system mainly the engine block. What I do is hook up a drain hose to the T connector, start engine and let the water pump push water out of the system. As soon as you see no water coming out turn engine off, remove drain hose and cap off T connector).
6. Close radiator drain plug and fill radiator with a 50-50 mix of antifreeze/distilled water (or buy premixed).
7. Start vehicle and bring to operating temperature to make sure thermostat opens. Add additional mixture as necessary until full.
8. Reinstall radiator cap.
9. Release any trapped air in cooling system by turning the plug on the top of the thermostat housing (be careful not to burn yourself). When only coolant (no air) flows from the plug, close it. You may have to repeat this several times to get all of the trapped air. Raising the front end of the car where the radiator is higher than the engine helps bleeding.
10. Add additional coolant as necessary. Also, fill overflow bottle to recommended level. Be careful not to open radiator cap if hot. You may have to do this several times.
11. Check for leaks.
12. Properly dispose of old antifreeze.
Timeslip 08/12/06
AF Community Guidelines
