Old 10-01-2002, 06:31 PM
illmatic illmatic is offline
springs
ey where can i get stock springs for the sedan?
what do you think is advisible
a. cutting the springs?
b. buying lowering springs?
c. clamping the springs?
Old 10-01-2002, 06:45 PM
GTA's Avatar
GTA GTA is offline
Whee..
I'd say get a set of lowering springs. I've heard of clampping but never tried. I have had cut springs and they just plan sucked. The ride was extremly bouncy and i ended up denting my front fenders from the shocks bottoming out and allowing the tire to hit the top of the fenderwell. Get a set of progressive rate lowering spring, they give you a better ride than non-progressive and also replace you stock shocks if you havent done so already.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-01-2002, 06:48 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Don't cut your springs. You'll regret it. It destroys the springs properties (which are matched to your shocks), and you'll end up with a HORRIBLE ride.
I don't know what clamping is, but it sounds kinda dodgy.
I would really recommend some good lowering springs or coil-overs.
Old 10-01-2002, 07:24 PM
GTA's Avatar
GTA GTA is offline
Whee..
clamping means to put a clamp on 2 coils to bring em together, which allows to car to go lower.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 10-01-2002, 10:47 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
B. because thats the best way to go, if you wanna use ur stock springs, just have em HEATED, my friend does this, and he does it pretty good, he heated springs on a 94 accord wagon and it looks good, and feels good, not as good as springs, but its still better than cutting the springs, and if you clamp the springs, do it onthe BOTTOM end, the very bottom ones, not somewhere in the middle, or on top.
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-02-2002, 01:46 AM
91civicDXdude's Avatar
88-2000 civic coilovers....89 bucks
http://www.truckn-store.com/product....t.asp&ID=18360
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 08:25 PM
SiRedge: Heavy duty springs (worth a look for anyone interested in spring heights) Setanta '71-'87 Civic | CRX 0 02-20-2002 11:46 PM
Ground Control adjustable springs VS. lowering springs AznDragon Tires and Wheels 3 02-17-2002 05:21 PM
Springs, springs, springs... sparq Tires and Wheels 14 01-21-2002 09:15 AM
Best spring shock comboand online price for springs????? 02G20T Suspension 3 05-15-2001 10:44 AM
