Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 02-11-2007, 07:29 PM
bsilverado00's Avatar
bsilverado00 bsilverado00 is offline
Best intake for a 5.0
I have a 92 Lx 5.0, in the process of upgrading. Gonna go with Afr heads(165), E303 cam, usual 1.6 roller rockers, 70mm TB and spacer, whats the best intake for steet use? Been out of the 5.0 scene for a while. If it matters, it's a vert with an automatic,TCI saturday nite special converter, 3.08 gears. Soon to be 3.73's. What's best?
2000 1500 2WD
7" Fabtech Lift
MT Baja MTX's on MT Classic II's
Old 02-11-2007, 11:53 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Best intake for a 5.0
With that cam and those heads I'd suggest a Cobra or GT40 intake with some mild port work. Or you could step up to a nice TFS or Edelbrock intake, something around the track heat or performer series.
1969 Cougar
357w & TKO - 475hp
Old 02-12-2007, 09:03 AM
Pimpdady753 Pimpdady753 is offline
yeah i would go with the TFS, ive herd good things about the BBK SSI tho,
Old 02-12-2007, 10:36 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
A GT40/Cobra intake would work well but then I advise hunting out a 96 Explorer intake exact same part just a lot cheaper.
If your going AFR heads I would move away from Ford intakes and look at TrickFlow, Edlebrock, Holley etc.., The ports sizes match up better without having to do port work and will maximize your heads a lot more.
I'd favor the TFS the Holley is huge and seems best suited for small cubed FI engines. The TFS trackheat is very nice and the ports match up to AFR's very well. Edelbrock Performer RPM I or II would work fine too.
Ask around about cams, the alphabet cams are rather dated and there are a quite a few superior off the shelf grinds available.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-12-2007, 01:28 PM
351wStang's Avatar
While this is true, in the right application the abc cams are a great bang for the buck. Another popular camshaft for 5.0 guys is the Crane 2031.
1969 Cougar
357w & TKO - 475hp
Old 02-12-2007, 07:57 PM
GTStang's Avatar
Stang Guy
They are not bad but for the $20-$30 more dollars for some of Crane/Comp/Isky etc.., of the shelf grinds is money well spent.
But nothing wrong with the alphabet cams by any means
Old 02-13-2007, 08:46 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
The Gt-40 intake will handle 450 horse while the Cobra will handle 400.
Old 02-13-2007, 01:01 PM
351wStang's Avatar
I'm making over 600fwhp with a performer rpm intake. While I'm sure its not real efficient it works none the less. I'm just wondering where you get your information. The intake wont be a very big limiting factor in this type of build.
1969 Cougar
357w & TKO - 475hp
Old 02-13-2007, 08:07 PM
I read that out of a summit catalog.
Old 02-13-2007, 10:38 PM
351wStang's Avatar
Ah, I see. Summit and their hp quotes.. To be honest with you the best intake for this build in my opinion would be the track heat. It has nice long runners that will provide plenty of torque, yet it is opened up enough to be pretty efficient under 500fwhp. After the mid 400fw range I would suggest the Holley intake or a single plane carb intake converted to EFI.
1969 Cougar
357w & TKO - 475hp
Old 02-13-2007, 10:41 PM
GTStang's Avatar
Stang Guy
Cobra, GT40, Explorer intakes are all the exact same intake inside but different outward appaearances. They have been tested over and over again to flow within 3CFM of each other.
Old 02-15-2007, 06:55 PM
Thanks for all the replies, but I did forget to mention that I'm gonna try to make this pass NJ emissions, so I'm leaning towards TF street heat. As far as the cam selection, I have to do a little more research, I just picked up a set of 1.7 roller rockers.
2000 1500 2WD
7" Fabtech Lift
Old 02-19-2007, 09:37 AM
mustangman02232 mustangman02232 is offline
Send a message via AIM to mustangman02232 Send a message via MSN to mustangman02232 Send a message via Yahoo to mustangman02232
if your buying based on that then you better put a dart shortblock on the list
2004 F350 6.0 4x4 auto SRW
SCT X3 with innovative tunes, autometer boost/trans/pyro, AFE stage 2, MBRP 4" no muffler or cat, EGR delete, ARP studs, 8' fisher MM2, misc appearance
90 F350 7.3 IDI 4x4 SRW (sold)
bolt on 02 mustang 232 4R70W vert (sold)
built 88 toyota pickup (sold)
bolt on 92 camaro LO3 TBI (sold)
