| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Radiator Fluid leak? Can't find source.
I pulled my 1997 Chevy 2500 350 5.7liter truck into my driveway and then i hear a hissing sound then white smoke came out from under my hood. I then discoverd Radiator fluid dripping from the bottom rear of the engine block, right behind the oil pan but I don't know where its flowing from. My temp gauge is stuck at 250 and the temp gauge installed only goes up to 195. What happened? The truck runs fine when i started it again but I obviously didn't drive it. I used to live in NY and everything on the truck is to NY specs and living in Florida now the temperatures here are much higher.
Re: Radiator Fluid leak? Can't find source.
Sounds like a pretty common problem... sounds like your thermostat stuck closed and caused excess pressure to blow the intake seal at the back. Its a common leak point on vortecs; at the rear water crossover where the intake meets the head.
Dragging people kicking and screaming into the enlightenment. |
hope it is not a soft plug.
as curt said, intake manifold gasket is very common on those. not uncommon to see them leaking every 50K miles
life begins at 10psi of boost Three turbo'd motorcycles and counting.
