Old 02-04-2007, 01:11 PM
MamuSpral MamuSpral is offline
99 Grand Am axle nut torque
I am replacing a drive axle on a 99 GA and was wondering how much to torque the axle nut to. If someone has a manual and can look this up it would be much appreciated. I am using a rebuilt axle assembly bought from canadian tire but it didnt contain installation instructions.
Thanks
Old 02-04-2007, 04:49 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
Re: 99 Grand Am axle nut torque
284 ft lbs
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 02-04-2007, 05:35 PM
BNaylor's Avatar
BNaylor BNaylor is offline
There are two different axle nut designs, therefore the possibility of two different torque values. There is a PAC Nut which most '99 and up Grand Ams should have but also, there is a second design. First design (Black PAC Nut) is 284 ft-lbs with a new axle nut. The old axle PAC Nut should not be reused. Second design (solid gray) is 173 ft-lbs.
1st Design PAC Nut
Pac Nuts are laminated lock nuts designed to internally deflect as torque is applied. This deflection or spring loading occurs below and through the bolt stretch or elastic range, adding to the bolt's capability to maintain preload. Preload maintenance is fundamental to preventing joint loosening.
Advantages of a PacNut®
Joint loosening prevention - The internal deflection of the conical laminations in the nut result in a reduction of hole size or pitch diameter eliminating designed clearance between the nut and bolt. This also produces mechanical pressure to the flanks of both male and female threads. The spring pressure and mechanical interference results in locking or resistance to loosening.
Torque/Tension - Solid nuts characteristically concentrate the majority of loading at the bottom one and one half to two threads. This eccentric loading causes the nut to dilate and increases friction in the highly loaded thread contact area. This results in increased torque/tension. Torque/tension relationships with the Pac Nut are maintained through controlled spring deflection, resulting in uniform thread loading form bottom to top of nut. Pac Nut laminations are specifically designed with varied thickness and crowned configuration of the laminations bottom to top to allow equal thread load distribution.
Timeslip 08/12/06
AF Community Guidelines
Old 02-04-2007, 09:21 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Good Post on the PAC Nut Bob
1999 Grand Am SS 3.4 OHV
Old 02-04-2007, 09:46 PM
BNaylor's Avatar
How about them Colts JC!!!!!! Bears are owned!!! Back on topic.
Thanks. Good data for your new GA Tips & Maintenance subforum.
Timeslip 08/12/06
Old 02-05-2007, 12:08 PM
That was a great game !!
The first quarter was the best
I will put this info to good use
Old 02-05-2007, 02:13 PM
crazy Jim's Avatar
1st quarter: two fumbles lost, two inteceptions, one missed extra point, one star running back injured. I think that both teams would rather forget the first quarter. Indy particularly did not like the opening kick off being returned either, although they did make Chi Town pay....
current vehicles:
'02 Impala LS 3.8L
'04 YZ450F
