Old 02-04-2007, 01:03 PM
chevcamaro_86 chevcamaro_86 is offline
wrong topic but got a question
i ask this forum because everyone seems more noligable and is more willing to leave messages. anyways does anyone know what the fiberglass mix for custum fabrication is called and how much it will cost me i dont know how much ill need so just give me a minimum price for how much material greatly apreaciated.
Old 02-04-2007, 01:37 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: wrong topic but got a question
There is a fabrication forum here as well. You might get more detailed responses there. Go up to the main tree and its immediately below this forum.
You're looking for fiberglass cloth or matting and polyester resin and hardener. Its available at parts stores or Home Depot/Lowes. Its been a while since I bought any, but I think it should be about $25 a gallon for the resin/hardener and another $15-20 should buy enough cloth to use that much resin. For good looking stuff, get the woven cloth that looks like burlap; evenly woven. For stronger stuff thats not as pretty, get the randomly oriented cloth. It comes in a few thicknesses up to about 1/4" thick. That stuff is strong as an ox, but not easy to get a nice flat finish. For the ultimate strength, skip the poly resin and go to an auto body supply place and get epoxy. Similar working properties but much stronger when done.
Dragging people kicking and screaming into the enlightenment.
Old 02-04-2007, 01:53 PM
thanks the reason why i diddnt go to the fabrication forum was because i looked in it and there was no posts. will this material be good enough for body replacement pieces such as custom fenders or bumpers?
Old 02-05-2007, 01:28 AM
curtis73's Avatar
Sure. It depends on what you're trying to do. If you're adding decorative parts its fine, but if you are replacing parts like fenders you'll have to be careful of stress points. If you make a custom fender that isn't strong enough, the first bump you hit will rip it off right at the bolts.
Old 02-05-2007, 12:38 PM
midgetracing28's Avatar
midgetracing28 midgetracing28 is offline
Send a message via MSN to midgetracing28 Send a message via Yahoo to midgetracing28
You could probably make a custom fender if u simply added to the existing fender.
