Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 01-29-2007, 08:08 PM
micali micali is offline
how to program a keyless remote for 99 avalon
I've check all forums and cna't find it. How do I program my keyless remote for a 99 Avalon xls. It is the factory installed version. Is it the same for the 2000?
Old 01-31-2007, 09:48 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: how to program a keyless remote for 99 avalon
Even tho Toyota says the GQ43VT7T remote was only used from 95-98 in the Avalons, here are the instructions for that remote:
1. Remove key from ignition
2. Locate bulb failure warning module in truck near left trunk
hinge and disconnect electrical connector.
3. Jump pins 2 & 10 of connector with short wire or paper clip
4. Door locks will cycle
5. Press any button on remote keyless entry entry transmitter
6. Door locks will cycle
7. Repeat steps 5 & 6 for another transmitter
8. Remove jumper from connector and reconnect to module
NOTE: A max of 4 transmitters can be programmed to a car
NOTE: Entering programming mode erases all previously
programmed transmitters.
Direct Link - http://originalkeyless.com/searchqui...eywords=Avalon
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 01-31-2007, 10:08 PM
If you say that then how else can you find out what is supposed to work for that year? The dealerships don't know s*&t! They are worthless.
All I can go off is what my manual says and it says use fcc #GQ43VT7T.
Old 02-01-2007, 11:51 AM
Onblsht's Avatar
Authorized Vendor
According to the TSB from Toyota, the GQ43VT7T remote is used only on the 95-98 Avalons with the FACTORY remote system.
The 96-97 use the BLACK RS3000 remote for the dealer/port system.
The 98-99 use the GRAY RS3000 remote for the dealer port system.
The 98-99 use HYQ1512Y for the FACTORY remote system.
The 00-04 use HYQ12BAN for the FACTORY remote system.
Old 02-05-2007, 05:25 PM
is there a way to tell which one you have? I do not have anyting in the trunk. No black box's.
Old 02-05-2007, 05:45 PM
I pulled the side panel away and notice a green box and a black box under it. Does this have anything to do with it?
Old 02-17-2007, 12:38 PM
Go to http://programyourremote.com/. They tell you how to program your remote. car and year specific. They only tell you how to do it for factory installed systems
Old 04-09-2007, 10:40 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Good find!
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-10-2007, 07:30 PM
I have a dealer installed system and I did get my remote programed. It is very easy to do.
Old 08-30-2007, 11:18 AM
Steburd's Avatar
Steburd Steburd is offline
Originally Posted by Onblsht
NOTE: A max of 2 transmitters can be programmed to a car
I have 4 remotes for my 99 Avalon. The programming did not erase previous ones.
Old 08-30-2007, 03:31 PM
csaxon csaxon is offline
That's correct 4 per car.
It worked fine until I fixed it!
