Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 01-28-2007, 11:34 AM
1988civicdx 1988civicdx is offline
Question map sensor problem maybe??
i have a 88 honda civic dx with the 1.5 litr in it and i have a problem when you start the car it starts to miss and when it warms up it wants to die, on the road driving wise the car misses and carries on and has no power, you can smell fuel badly in the car and my car smokes black, my ecu is throwing 2 codes.....one code is for the fuel injectors and the other code is for the map sensor, before the headgasket was done on the car it ran fine, but now it does not want to run at all....the car is in time, new plugs...wires...and the dizzy is alright....maybe my problem is all in the map sensor......help
Old 01-28-2007, 11:45 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: map sensor problem maybe??
Could be. See if you can get your hands on a map sensor from a friend just to swap to see if the problem clears up. If it does then go buy the new one.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-29-2007, 03:24 PM
swapped out the map sensor and still the same problem, i am about to get rid of this thing, i dont know what else it could be???
Old 01-29-2007, 11:36 PM
808hardbody's Avatar
808hardbody 808hardbody is offline
did you plug the right plugs in. The map sensor plug connector can be confused with others?
Old 01-30-2007, 12:41 AM
not that i can see, i will have to keep trying to find the problem...i appreciate your help
Old 01-30-2007, 01:44 AM
Hope this helps. It happen to me before.
________12.5....5psi. nuff sedd ___________
Old 04-03-2007, 02:44 AM
B16 SiRII's Avatar
B16 SiRII B16 SiRII is offline
Send a message via AIM to B16 SiRII
Check all the little clips on the injectors, you may be leaking some fuel out if you smell it. Those clips tend to break easily if they've had any work done to them.
You may know me as Fakter1 on other forums.
Old 08-19-2007, 04:30 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
check vacuum hoses make sure they r routed right
