Old 01-26-2007, 08:04 AM
ICCS ICCS is offline
Removing Dash Trim Bezel 2000 GP GT
Greetings,
I purchased a vehicle specific mount (VSM) for my XM satellite radio, see this link for a photo, http://store.xmfanstore.com/vsm.html
It requires that I remove the dash trim bezel in order to secure the VSM behind the dash trim.
I have the instrucitons from the manufacture but I'm a little uneasy about removing the bezel. They say to use caution as some of the clips can come loose and/or fall behind the dash. Any tips on how to remove this bezel without losing clips and/or damaging the trim/bezel.
Many thanks.
Old 01-26-2007, 08:48 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Removing Dash Trim Bezel 2000 GP GT
Checkout the link below. It should cover 2000 and up even though it says up to '99. There are several retaining clips that hold the dash bezel and you have to pull out but be careful not to break anything.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 01-27-2007, 07:29 AM
Excellent, thank you.
I guess the trick is to take it slow and just ease the bezel off?
Old 01-27-2007, 09:28 AM
BNaylor's Avatar
You're welcome.
Carefully, but firmly. There are several clips holding it in. Start with the portion that covers the radio and climate control units. Also, lower the steering column all the way before you start. Once the panel is removed, disconnect the fog lamp switch using a screwdriver and set aside the panel. Thats it and good luck.
Timeslip 08/12/06
