Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-23-2007, 11:18 PM
jason borne jason borne is offline
starting problems
i have a 1991 3.1 camaro, my problem is this when i dont start my car for about a couple of hours it has a hard time turning over. it only clicks once for every key turn. i have to get it jumped in order to get it started. once it is started, after that it will start every time until it sits for a long while.i will appriciate any help thanks.
Old 01-23-2007, 11:25 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: starting problems
have you had the battery tested?
Seatbelts Saved My Life
Old 01-23-2007, 11:35 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
And have you had the starter tested?
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 01-24-2007, 09:48 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Umm, I'm going to go simple for a second here and say to make sure all the electrical connections on the alt., starter, and battery are clean and tight.
Old 01-26-2007, 10:53 AM
kunengine kunengine is offline
Banned
my mercedes benz m class, i removed the battery and since then its been sparking when reconected, i was told its need programig, how do i fix this? how do i get it started.
Old 01-26-2007, 11:06 AM
wrightz28's Avatar
Although this is not the Mercedes forum,, if you go to reconnect the battery and there is a spark, that sparks indicated taht somthing is pulling amperage at pretty good amount that shouldn't be.
In all reality tho, try the Mercedies area out
