Old 09-27-2002, 05:04 AM
yakatui yakatui is offline
help - which speakers to get
I just got a 96 cavalier, it has a cassete deck and the front speakers are about to blow. I was planning on getting a cd deck for around $180-200 (probably pioneer, kenwood, or alpine) and either 4x6 (which the stock speakers are in the front door) or 5 1/4 or 6 1/2 components. I was wondering which type of speakers would be the best bang for buck (low budget). I am not planning on buying an amp or subs. Could a aftermarket cd deck for about that much give enough power to actually use the benefits of components or would I be better off just getting some new 4x6's?
Any input will be greatly appreciated
Old 09-27-2002, 10:47 AM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
THe 4x6 will be the most inexpensive route. Pioneer and Infinity makes good 4x6's. If you ever plan on getting an amp then look at getting a kickpanel with a component set to go in it. I would recommend Diamond Audio's CM3 series component set (had to plug my peeps somehow).
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 09-27-2002, 01:07 PM
350z4me 350z4me is offline
well the 4x6s are the ceapest but if you want a little bass u should do what lloyd said some other good components are rockford fantastic X pioneer also has a cheap pair of components.
Old 09-28-2002, 11:49 PM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
sure 4 x 6 is the easy option but you will probably regret it in the long run so you may as well save the money and get a decent set of components put in there to begin with.
Old 10-03-2002, 06:04 AM
Exclamation concern over the component set
My only concern is if he doesn't use an amplifier for the component set he will run the risk of blowing them through distortion. Especially the tweeters (which are retarded expensive to replace by themselves). I will stick by what I said, no power amp = no components.
which speakers should i get? Fed Car Audio 6 08-17-2006 12:32 PM
Which speakers do i get? JohnC24 Car Audio 9 11-16-2004 09:05 AM
HELP!!!!Which turbo kit should I get? hondachief21 Forced Induction 5 09-04-2004 01:52 AM
which speakers KeGrO Car Audio 6 05-30-2003 01:02 AM
Which speakers to buy.... Spec-V Car Audio 21 12-29-2001 03:03 PM
