Old 01-20-2007, 03:27 PM
chevcamaro_86 chevcamaro_86 is offline
Thumbs up what should i get
with my third generation camaro should i put a 305 in it or a 350 and if so what transmission should i get if i want a manuel and the engine is putting out some serious power.
Old 01-20-2007, 05:25 PM
UncleBob UncleBob is offline
AF -Advisor
Re: what should i get
305's, although capable of making good power, are lacking. A 350 would be a much better choice if power is your goal.
Can't help yah on manual trannies
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-25-2007, 09:49 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Do a 350. It will cost the same (or maybe less) and make way more power.
For serious power, you have two choices: T56 six speed or T5 5-speed, both of which fit an F-body since they were offered from the factory. A 94 and later T56 will take 450 lb-ft of torque pretty regularly. A T5 in stock form is only good for about 300-350 lb-ft, but aftermarket TKO T5s will take 500-600.
Either way, the tranny will take more power than your rear axle will. The tranny won't be the weak point.
Dragging people kicking and screaming into the enlightenment.
