Old 09-25-2002, 09:05 PM
95ACCORDEX 95ACCORDEX is offline
anyone have this problem with the windows???
my windows are starting to go up and down pretty slow. is there any thing that i can do to make it move smoother and faster? i know this happens to cars as they get old but is there any way to fix this problem?
Old 09-25-2002, 09:53 PM
Phat8186 Phat8186 is offline
Send a message via AIM to Phat8186
I am having the same dam prolem with my windows. I have a96 honda accord 4 door sedan ex model. My two front windows take forever to go up and go down.
Old 09-25-2002, 10:22 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Same here!!
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 09-26-2002, 04:07 PM
Duatone Duatone is offline
ah yes, the very famous window problem with your 4th and 5th gen accord..I don't know why, but honda sucked when they put these babies together..anyways, heres what you do, and yes, ive done this myself numerous times, depending on how technical you want to get or how much spare change you want to say bye too (which isn't much) go out and buy a new window motor, (in the cheap case get it fron a junk yard), or if your really cheap and lazy, lube up the rubber gasket that runs around the window with WD40 or something similar, and your window should go up and down faster than your car on cut springs on that really bad road you just can't avoid (you know which one)... but you have to re-apply your lube often, so ive found it easier to just replace the motor.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 10-06-2002, 04:03 PM
hondagirl hondagirl is offline
Send a message via AIM to hondagirl
yep yep...my 97 4 dr ex does the same thing...
i just deal with it..
KIM
Old 02-03-2003, 11:53 AM
Squintz0321 Squintz0321 is offline
Send a message via AIM to Squintz0321
My shit be doin the same thing an I was wonderin what the problem was. But I guess I am gonna have to get a new motor.
1996 Honda Accord LX sedan/ Hyperwhite corner lenses-bulbs/ Huperwhite bumperlenses-bulbs/ Generation II Euro Tails/ 35% tint.......
Old 02-03-2003, 12:40 PM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
fyi, its not just the motor, it is the whole assy. You can get them from junkyards yes, but the motor specifically is just part of the problem as it is massively undersized to begin with, and will be essentially the same as the one you are taking out as it is from the junkyard. However, this is a blanket statement, some yards rebuild and give a warranty, check before you buy. More important overall is the whole regulator assembly itself, they wear out over time, well in this case, very quickly.
accordstore.com has these "kits". Its where I got mine and will take you about an hour or two to get both sides done at a leisurely pace. search for "window regulator " and you'll hit it right away. These are only for the G5 accords tho, sorry G4s, dunno where to send you. No it isn't cheap, but it will last for years and is new. $270 is well worth it IMO.
Yeah, lubes will do the job, but as mentioned you have to reapply and they dirty up the window.
If you plan on keeping the car, just replace them like I did. You will be much much happier.
fyi, junkyards should run about $55-$90 for the part (inc motor), per side
Anyone Ever Have This Problem With A Rodeo? weathermedic Rodeo | Passport | MU 1 05-31-2007 10:10 PM
Help! My 98 accord is dying! anyone have this problem before! Help! bans25 Accord/TSX/Accord Hybrid 0 10-25-2003 07:00 PM
Anyone have any problems with noises under the car mano77 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-24-2003 07:33 PM
