Old 01-17-2007, 02:07 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Passed emissions but noticed why my steering wheel wobbles!
I'm so relieved to pass emissions, just because to pay for repairs would suck
1992 Eagle summit 1.5 hatch
(especially on this car)
now when the car was on the machine I noticed that the driver's front wheel has a wobble, this is not tire balancing, this is probably from me that day before I rented a hub puller yanking and prying that hub off (which never can off)
can I just replace the wheel bearing? Would this fix the job?
Feel like a loser, since that wobble is probably not that safe and cuts down on gas mileage (not to mention embarassing when the friggin wheel shakes all around over 60
http://www.georides.com
Sub Compacts, Electrics, Biodiesel, hydrogen
Old 01-17-2007, 02:33 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Passed emissions but noticed why my steering wheel wobbles!
I'd take the wheel off and put it on a spin balancer, not to balance it, but to watch it. A bent wheel is a common thing.
Dragging people kicking and screaming into the enlightenment.
Old 01-17-2007, 02:35 PM
so hmm, I think while I have the wheel up to tighten the axel (doubt it can be tightened, I'll just change out that tiah with one form the back
thanks
g
Old 01-17-2007, 02:40 PM
curtis73's Avatar
Don't just tighten the axle. Those bearings have a very specific torque requirement. If its not making noise, DON'T TOUCH IT. You'll destroy it.
They can't wobble unless they're totally trashed, in which case it wouldn't be drivable. Its not the bearings.
Old 01-17-2007, 06:56 PM
so would it be worth to true the wheel? maybe it's all my sportscah driving with these snow tiahs I have on, grip everything
so i didn't screw up the hub/bearings? just thought so because it was the same wheel I was awhacking awahy on.
grimmace
Old 01-17-2007, 07:22 PM
curtis73's Avatar
Truing a wheel usually costs as much as a whole new set of fancy chromies. For that kind of money you can buy a couple factory wheels, depending on which ones they are... aluminum? steel?
If you screwed up the bearings or the hub, it will let you know by making horrific grinding noises, not wobbling. Even the worst bearing won't make the wheel wobble.
Old 01-20-2007, 07:17 PM
OK, so it is, these are snow lug wheels but i do alot of highway, thinking it would be worth the $20 or whatever to balance them.
what's the going rate for balancing and what should I ask for? Dynamic, etc?
Old 01-21-2007, 12:36 PM
UncleBob UncleBob is offline
AF -Advisor
you need to isolate where the problem is. First you need to verify that its not slop in the suspension or bearing. Jack the tire off the ground, grab the rim and try to move it. It should not have any slop at all in any direction. If you find slop, isolate where it is
After that, I would take the tire to a tire shop and have them balance it, and watch for rim run out on the balancer. If it has none, that leaves a bent hub.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
