Old 01-17-2007, 01:03 PM
JennyJenn's Avatar
JennyJenn JennyJenn is offline
Please Help!
Hello I have an 02 alero 2.2 manual trans. and it will not start. It ran fine all day... parked the car overnight would not start the next morning. all the lights radio chimes work great but car will not turn over. I also tried to jump it, thinking it could be a dead battery and it would not jump... Please help!
Thanks
Old 01-17-2007, 01:44 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Please Help!
Welcome to AF.
You may have a Passlock VATS problem which is common in Aleros. Is there a SECURITY light on or flashing at the Instrument Panel?
If so leave the key to the ON position for approximately up to 10 minutes until the light goes out and then try to start.
Timeslip 08/12/06
AF Community Guidelines
Old 01-17-2007, 02:03 PM
JennyJenn's Avatar
Re: Please Help!
The light security light is on. I tried the 10 minute thing but still won't start
Old 01-17-2007, 02:16 PM
BNaylor's Avatar
Re: Please Help!
Until you get the SECURITY light out it will not start. It cuts off voltage to the starter and fuel injectors.
Disconnect the battery negative cable for several minutes and then reconnect. Then try the re-learn again. Key to ON not START position for 10 minutes and off for 30 minutes. Repeat. If light does not extinguish then you may have an ignition switch key cylinder problem because the coding is not being passed on to the Body Control Module (BCM) which handles the anti-theft deterrent system.
Timeslip 08/12/06
Old 01-17-2007, 05:09 PM
JennyJenn's Avatar
Re: Please Help!
Ok so I got mad and started looking under the hood, thats when I realized that I have no compression, and hardly any spark. There is enough spark to trigger fuel, and cause the car to flood but not enough to start the car. So now what?
Old 01-18-2007, 09:55 AM
caddyman379 caddyman379 is offline
Re: Please Help!
Perhaps your confused. Is the engine cranking when you turn the key to the start position, or no?
There wouldn't be any compression if the pistons aren't moving.
Old 01-18-2007, 10:31 AM
JennyJenn's Avatar
Re: Please Help!
It cranks but doesn't turn over.
Old 01-18-2007, 04:23 PM
BNaylor's Avatar
Re: Please Help!
What is the status of the SECURITY light now?
Timeslip 08/12/06
Old 02-18-2007, 05:30 PM
JennyJenn's Avatar
Re: Please Help!
Ok so I guess it slipped time, they told me that the oiler went bad.
