Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 01-15-2007, 03:44 PM
NthN NthN is offline
1999 unstable revs help
Hello everyone,
I have a 1992 Honda Civic Hatchback with a 1999 engine with a cold air intake and 1999 transmission.
When I start the engine, it revs 2500 then slowy up to 3200, and then it drops down to around 2300 and rev up to 3200. It keeps doing that every seconde. The engine overheat, when I turn the heat on, it doesn't blow the heat out of the engine. It sounds like the engine is looking for something.
I chane the oil, anti freeze and the thermostat. The dash board doesn't indicate anything.
Anyone knows what is the problem?
Old 01-15-2007, 05:06 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: 1999 unstable revs help
When did this start happening?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-15-2007, 07:55 PM
It happened 2 days ago.
Old 01-15-2007, 07:59 PM
NA is Best!
Out of nowhere? Did you change or do anything out of the ordinary? Reason I'm asking is because Hondas do the idle surge becuase of many problems.
Old 01-15-2007, 09:48 PM
Yes. It happened 2-3 min after I started the engine 2 days ago, out of no where.
I changed the transmission this summer and ran really good. I thought it may be thermostat, so I changed today, but the revs still go up and down.
Old 01-17-2007, 05:35 PM
NA is Best!
Could be a vaccum leak. Check all the lines. Could also be the IAC got stuck open. Fix here.
