Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-12-2007, 02:50 PM
ynghank ynghank is offline
No Heat
My 95 is blowing cool air, when the engine is hot the air is luke warm, and that may be an overstatement. I can turn the fan to the differant ranges and the temperature gauge seems to work fine. I wasted time changing the thermastat last week. Any suggestions would be greatly appreciated.
Old 01-13-2007, 10:55 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: No Heat
Check the heater inlet and outlet hoses from the water pump going to the heater core at the firewall. Are they both hot to the touch after engine warms up?
Another possibility is a temperature actuator problem with the climate control system.
Timeslip 08/12/06
AF Community Guidelines
Old 01-17-2007, 08:08 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: No Heat
did you have eat before you changed the thermostat?
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 01-19-2007, 09:38 AM
Re: No Heat
No, i changed the thermastat thinking the may have been the problem, I had heat last year. The AC was working last year aslo but not anymore.
Old 01-22-2007, 06:48 AM
Re: No Heat
Is it possible to shift the vent or actuator to allow the heat into the car?
