Old 09-24-2002, 06:13 AM
stock1.5 stock1.5 is offline
Lightbulb std madness
okay i was wondering if its possible to bore a 1.5 to a 1.6? is the 1.5l engine block the same size as the 1.6 only with a smaller bore? i have this idea to just completely bang out the standard to its fullest of its potential.. or jus swap it out for a d16z6/y8. but i ask cause i know someone who can do this for me at a very good price granted that its possible and would even be worth the hassle. if so i would it be as simple as puting on an si head, wiring in the vtec, installing si rods and pistons, switching from dpfi to mpfi and swapping in the si tranny. has anyone here tried to max out a std?:ylsuper
IM RICK JAMES BITCH
Old 09-24-2002, 01:14 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
it really depends on how serious you are. your std can run a 12 sec 1/4 mi. on a junkyard turbo and not nearly as expensive as you would imagine!
the difference between std and si? the cam has a slightly different grind, MPFI, 0.1L, and the tranny. no, tranny doesn't give you hp...but the better gears help. so then there is the cam grind. that isn't big enough to make much of a difference. the 0.1L...that small amount speaks for it's self. so what makes the big difference? MPFI...it is what makes the huge difference.
i'm sick of preaching about the 88dx who won battle of imports with a 12.31 sec pass at 112 mph. so hit 88CiViC_DX up, he read the article (for the most part).
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-24-2002, 08:40 PM
junkyard turbo? what exactly is a junkyard turbo and how do i get one? and if my car is bone stock can it handle a turbo?
IM RICK JAMES BITCH
Old 09-24-2002, 10:53 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
She is referring to a turbo system that you piece together yourself from parts of off other cars found in junkyards. Problem with this is you need to know what you need in the first place. And there is usually custom fabrication involved. But if you can do it, its fun to have a cheap turbo system.
Stop looking at my Autometer!
Old 09-25-2002, 04:12 AM
where can i get more information on something like this, the junkyard turbo i mean? like which turbos i can use and all parts needed and etc... if its a low cost type of thing it sounds like it would be fun til i get the funds for a swap.. because my car needs some serious go!!! like maybe a 240hp rear wheel drive f20c and 6 speed tranny from an s2000...mmm dual exhaust and all!! ya that'd be fun. when i win the lottery
IM RICK JAMES BITCH
Old 09-25-2002, 04:23 AM
GTA's Avatar
GTA GTA is offline
Whee..
www.homemadeturbo.com would be a start.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-25-2002, 12:12 PM
dropshop dropshop is offline
Send a message via AIM to dropshop
i sel junkyard turbo kits as well
theya re a lillt better engineered than the guys @ homade turbo and i provide a bolt on install
Turbo Kits
hi im jon and im addicted to boost
Old 09-25-2002, 12:57 PM
91civicDXdude's Avatar
correct me if im wrong, but i belive they all have the same bore just a bigger stroke on the 1.6L
Looking for a CD Changer for my 95 Q45 std 95Q45 Nissan Cima | Nissan President | Infiniti Q45 2 03-05-2003 10:53 AM
M5 std. Wheel size? INEEDACAR M5 3 01-27-2003 08:51 AM
Max Boost With Std. Intercooler -Joel- Performance 21 08-08-2002 12:46 PM
D16z6 in STD! Poweredbyhonda '88 - '91 Civic | CRX | Wagon | Shuttlee 15 05-27-2002 05:58 PM
STD R32 Skyline Manual, When Does Boost Develop -Joel- Performance 5 11-13-2001 10:03 PM
