Old 05-24-2002, 02:40 PM
Poweredbyhonda's Avatar
Poweredbyhonda Poweredbyhonda is offline
Send a message via AIM to Poweredbyhonda
D16z6 in STD!
Hello, i am going to be doing this swap soon and i heard that u need to swap knuckles and hubs? Is this true? will i need new axles? since my car is a 4spd?
thanx:smoker:
Kyle Cox
project eg hatch in progress
http://www.nsmotosports.cjb.com
:badass:
Old 05-24-2002, 04:17 PM
Also, How will i get around OBD-1?
Also what are the vtec pinouts? (ex. a5?) Oil pressure? (c5?)
thanx
Kyle Cox
:badass:
Old 05-24-2002, 06:28 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
You need to either buy a conversion harness, or re-wire your existing harness for the OBD-1 stuff.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 05-24-2002, 08:38 PM
Rgacke's Avatar
Rgacke Rgacke is offline
http://www.geocities.com/kurtsi_on/page7.html
this should help ya on the pins
"shut the door Joshua, and let death pass by..."
Old 05-25-2002, 07:35 AM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
A friend of mine has a 90 Civic base and wants to do the B16 swap. Will he need to get new hubs or can you use the base model ones. Also on the wiring, you have to hack the base motor harness. You can't use the one from another model because the plugs on the chassis harness are different.
Old 05-25-2002, 02:01 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: D16z6 in STD!
thanx:smoker:
no because it is still d series. but you need to if you go with b series.
however, i would seriously consider switching to a 4th gen Si tranny. i've had 4 dx's before the Si. it's hard to explain but....wow, what a difference a tranny makes! the Si tranny has a better gear ratio.
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-25-2002, 05:11 PM
I heard that if i use a 5spd transmission i will have to change my hubs and knuckles because they are 4spd! Is this true?
thanx for the replys!
Kyle Cox
:badass:
Old 05-25-2002, 05:14 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
yes
Old 05-25-2002, 05:16 PM
mellowboy's Avatar
For the wiring part i don't really know. If his car is a 4spd then YES he has to change the hubs. He will also need new axles from 90-93 integra.
Old 05-26-2002, 01:17 AM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
No,you cant use 90-93 Integra axels with the D16Z6. You will have to change the hubs but then just use the D16A6 axels because they will slide right into the Si tranny and also get the Civic/CRX Si hubs, that way everything will fit in just fine. I put the D16Z6 into my CRX so if you have any problems just let me know. I think i can remember back that far.
95 Integra GS-R
[email protected]
Old 05-26-2002, 11:19 AM
mellowboy's Avatar
I'm talkin to sikocivic guy cause his friend wanted to do a B16 SWAP in his STD! READ MAN !
Old 05-26-2002, 01:37 PM
sorry..no need to yell. Im not trying to be an ass but your wrong again. He needs to use the 86-89 Integra axels with the 90-93 Integra inner joints if he's doing it on a 88-91 HB. It would be 90-93 integra full axels for a 92+ Civic.
95 Integra GS-R
[email protected]
Old 05-26-2002, 03:58 PM
Also, i might do a b18a out of a 91 teg., i know i will have to get new hubs,axles,tranny, ect. . . . , but what axles do i use, do i use the axles like what Red rocket said? or can i use something else?
thanx
Kyle Cox
:badass:
Old 05-27-2002, 01:10 AM
If you are going to do a B18A then use the 90-93 Integra axels with the 86-89 Integra outer joints. The reason i say that is because you will probably want your hubs off of a 88-91 Civic/CRX Si because those were originally 5 speed. If you need anymore help let me know.
95 Integra GS-R
[email protected]
Old 05-27-2002, 01:45 PM
mellowboy's Avatar
Ok i wonder why my 90-93 axles fit for my b16 swap??
