Old 09-23-2002, 11:15 AM
GTRRR GTRRR is offline
Tamiya NSX
I am just about to start my NSX and am seeking a bit of advice. I want to paint the body blue and the roof black like the older NSX's. What I want to know is should I paint the whole body blue and then mask off the top and spray the black over the blue or should I mask off the top and spray the bottom blue then mask the bottom and spray the top black. I was thinking the first option would be better but I am worried about the paint being really thick. Please Help.
Got Boost?
Old 09-23-2002, 12:45 PM
mp3z24's Avatar
mp3z24 mp3z24 is offline
masking the areas seperately would probably be your best bet.
that way, when you spray up to the masking tape, there will be a ridge created against the edge of the paint, but when you mask and spray the second color, the ridge will be painted up to by the second color.
if you are not ready to paint and mask like that, then i would tell you to paint the blue first, and then mask off and paint the black area. black over blue would be a lot easier than blue over black!!! painting it this way may leave a ridge where the masking tape was at, so you might run the risk of ruining the base coat if you try to rub the paint down to make the transition smooth. however, if you do this method, you can try to smooth the transition with clear coat...
many options!!
remember to primer the entire car first!!! then do your masking.
~Mike
CURRENT MODELING PROJECTS....
Tamiya Nissan R390GT (Body & Decals Remian), Fujimi Silvia S15 Autech (Body Paint), Tamiya RX7-R1 (Not much done), Revell New Beetle w/ Street Racer Upgrades (Scratch Building Body Kit), Tamiya Skyline GT-R (Body Paint), Tamiya Escort RS Cosworth Rally (Body Paint & Decals), Tamiya Jaccs Accord (Street Conversion) (Body Paint)
Old 09-23-2002, 01:00 PM
Veyron's Avatar
Veyron Veyron is offline
Mask the problem.
If you are going to mask one time, spray the body, mask and spray the top and immediately turn it upside down so at least some of the paint will flow away from the edge. Also, don't spray toward the edge of the tape, try to spray at a 90 degree angle, or somwthing to that effect, so as to reduce the build up at the edge of the tape. If you are using lacquer or water acrylics, you shouldn't have too much of an edge because of the amount that they shrink.
Old 09-23-2002, 01:08 PM
lotus_man's Avatar
lotus_man lotus_man is offline
I find realy thin coats of paint help, they 'seal' the edge of the tape without ridging to much. Also really good quality (i.e. thin) masking tape like Tamiya tape helps. Some people use Baremetal foil as a mask as it's about as thihn as you can get, so there is no edge for the paint to ridge against, but I've never tried this.
My current work-
Old 09-23-2002, 03:30 PM
Jay! Jay! is offline
Horizontally Opposed
When I did mine (sse it in the gallery), I painted it TS-8 Italian Red, then masked off the roof and painted X-1 black acrylic over it. The first time I masked off the "waistline" with bare metal foil then the rest of the body with Tamiya tape, the black bled all underneath the mask... I had to strip it totally.
The second time, I did it the same way, but after painting red and masking, I put down a light layer of TS-13 clear over the masking tape (I only used the Tamiya tape, fearing the bare metal foil was part of my problem the first time.) This served to seal the edge of the tape down and prevent any leaks this time. Much better result.
I don't think you really need to worry too much about the intersection line between the two colors, since it sits down in a pre-existing ridge along the body.
Hierarchy of Subaru:
(Click to see mine!)
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
