I have a 2001 Alero 2.4, auto, abs, et cetera... It has sent back four codes... I only know what one of them is, does anyone know what the other three are??
Codes : C 1232 which is the left front circuit open.... ABS sensor? B 2752 ? U 1000 ? U 1128? |
Re: Looking for code descriptions...
What are the problems you are having with the car related to these codes.
C1232 Left Front Wheel Speed Circuit Open (bad wheel sensor or electrical connector /wiring).
B2752 is body control module related - Horn Relay Coil Circuit Low (BCM) U1000 is Class 2 Serial Data Communications Malfunction U1128 is Loss of Communication with IRC
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 01-02-2007 at 07:01 PM. |
Need code descriptions for an alero...
I am looking for any information on what these codes might mean that came from my 2001 Olds Alero 2.4 auto...
GM will not release the codes to me unless they are the ones doing the diagnosice... And therefore, I wish to try to avoid the 75 dollar an hour labor charge and like a 65 dollar computer hookup charge... ' Any information on these codes or where I can find out what they mean would be awesome Codes are: C 1232 B 2752 U 1000 U 1128 I do know one of the codes has something to do with a bad ABS sensor in the front right.... Thanks for your time. -Brandon |
Re: Need code descriptions for an alero...
Not sure on the C and B but the U 1000 - Class 2 communication Malfunction and the U 1128 Loss of Communications with IRC.
1999 Grand Am SS 3.4 OHV
http://www.troublecodes.net/OBD2/ I struck out on the B2752 The C1232 is a OBD11 brake lamp waring circuit code. And as said the U codes is communication codes. I would clear codes and recheck code no. or recheck with a different scanner. The C1232 is not a good manf code for your year car. But does show up as a ABS manf spefic code left front wheel open sensor circuit code on a 2000 year And the B2752 I just can not find. Double check it for sure.\ What is the car doing or not doing or what is acting up?
MT,
I thought the B2752 might have been a B2757, which is Driver Memory 1 select switch CKT Low .
Looking for code descriptions... http://www.automotiveforums.com/vbul...d.php?t=657657<--Merged so will not show I'll merge the two together but the OP (akadye006) is hereby forewarned to comply with AF posting rules.
I did found some security system serial data codes. 2947/2948/2957/2958. Which could go with his loss of serial data.
It might help to use updated and/or current GM Diagnostic Trouble Codes (DTCs)
for OBD II (OBD-2) equipped GM vehicles instead of using old data or speculating. C1232 Left Front Wheel Speed Circuit Open (bad wheel sensor or electrical connector /wiring). B2752 is body control module related - Horn Relay Coil Circuit Low (BCM) U1000 is Class 2 Serial Data Communications Malfunction U1128 is Loss of Communication with IRC
Sorry guys I didnt seee his other post!
