Old 12-30-2006, 08:59 PM
tazze10 tazze10 is offline
Question power steering problem on chrysler sebring
have replaced p/s pump and hoses,but still very hard to turn steering wheel and sluggish.Out of ideas. HELP!!!!
Old 12-30-2006, 09:21 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: power steering problem on chrysler sebring
Leaking rack? Bad actuator valve?
Its possible you have a bad rack. It could be leaking internally past the seals. Its also possible that the valve that controls how much pressure and where it goes is bad. If its stuck it won't send pressure when you turn the wheel.
Dragging people kicking and screaming into the enlightenment.
Old 12-31-2006, 07:24 AM
thanks for the help.I thoughtnof that,but hoping it wasn't that xtreme thanks again
Old 12-31-2006, 01:41 PM
UncleBob UncleBob is offline
AF -Advisor
often refered to as "morning sickness", bad rack.
Not the funnest thing to change on a sebring.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 12-31-2006, 05:25 PM
hundahunta hundahunta is offline
good luck, you need to drop the subframe.
