Old 12-24-2006, 08:24 PM
ep-hatcher-510 ep-hatcher-510 is offline
Tamiya TS-30 Silver leaf
Might be a dumb question but can i spray clear coat over tamiya silver leaf (TS-30)? because i sparyed clear over a silver or aluminum a long time ago and it messed up the paint making it run off.
Old 12-24-2006, 08:34 PM
freakray freakray is offline
AF Modelrater
Re: Tamiya TS-30 Silver leaf
Yes you can.
Will it change the finish, yes it will.
Now let us ask you some questions, when did you spray the silver leaf and what type of clear do you plan on using.
With Tamiya clear, unless it is applied directly after the final coat of color, you need to wait at least a month to clear coat - this is because the Tamiya clear has a different cure rate to Tamiya color sprays.
AF User Guidelines
Old 12-24-2006, 09:37 PM
i will be using tamiya clear (ts-13). i just sprayed Sliver leaf today. and how will it change the finish?
Old 12-24-2006, 09:46 PM
AF Modelrater
More often than not, clears will change the appearance of the finish, on silver it often makes it look more aluminum.
If you sprayed the TS30 today, you'll have to wait at least 3 weeks before you clear it.
Why are you wanting to clearcoat?
AF User Guidelines
Old 12-24-2006, 11:11 PM
Whumbachumba's Avatar
Whumbachumba Whumbachumba is offline
I've never clear coated silver leaf, but with some of their other colors I can use the rattle can clear without any problems in a week. Also has alot to do with the humidity and temprature in your area though.
Current Project: '70.5 Camaro; Air-Cooled GB: '66 Beetle; Shelby 427 Cobra
Old 12-24-2006, 11:35 PM
im using that color on the body, and i always put few layers of clear on my models. just something i am use to doing. Thanks for the information tho, have a happy holidays.
Old 12-26-2006, 01:51 PM
01L2Cobra's Avatar
01L2Cobra 01L2Cobra is offline
It will make it darker and a little dull. I built a Tamyia Porsche 959 and painted it silver leaf. When I went over the sivler leaf on test peice it did make it look more aluminum than silver.
The ///M stands for Motorsports
