Old 12-24-2006, 08:30 AM
D.E D.E is offline
Send a message via MSN to D.E
Chevy Camaro -68 Z28 done!
Hello... I know I've forgotten to add any pictures to the wip thread, and now it is finished. I took a couple of pictures out in the garden, but I don't have much luck with my camera.
Well, note that the finish isnt great and neither is the detail, but I had fun building it and I like the style. Hope you do too. I wasnt gonna go with the spoiler but the paint got a little screwed up where it would go, so I put it there anyway. I have put an air intake/engine cover over the engine, painted in the body colour as a decoration.
These photos turned out good:
These did not:
C&C please. /Dennis
Old 12-24-2006, 11:03 AM
Dean23's Avatar
Dean23 Dean23 is offline
Re: Chevy Camaro -68 Z28 done!
Nice looking build. I love red camaros. Have you tried to polish the paint in order to give it some shine?
get me a hardtop with a decent engine and make sure it's got a big trunk
Dwight from Sin City
Modern cars - they all look like electric shavers
Marv from Sin City
Old 12-24-2006, 01:36 PM
D.E D.E is offline
Nah... I dont feel like putting money into buying a polishing kit.
Old 12-24-2006, 01:56 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Looks great, these cars are always amazing in red. What polishing "kit" are you looking at? First off what type of paint did you spray it with or do you most often use/plan to use. I have yet to buy a kit and have great results with some really inexpensive methods!!!!!
Keep up the great work!
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 12-24-2006, 04:50 PM
D.E D.E is offline
Well the finest grit sand paper I know where to find is 2000. To polish, do you not need like 12000? I use regular spray paint from the paint store. Plasti-kote or something like that.
Old 12-24-2006, 05:06 PM
ep-hatcher-510 ep-hatcher-510 is offline
what u can do it give it a few clear coats, let it dry for a few days, and take rubbing compound (i use the 3M one) and polish it up , i always have great results with it, great shine.
Old 12-24-2006, 05:18 PM
D.E D.E is offline
Yeah well, what is rubbing compound? Since english is not my native language, I dunno what to look for.
Old 12-24-2006, 10:07 PM
rsxse240 rsxse240 is offline
it really just looks as if you put to much paint on to fast. the build looks good as far as the style, stance and colors are concerned. the execution looks as though it needs improvement.
for polishing out your paint, go to the local beauty store, and get a fingernail buffing stick. there are several kinds, get the kind that has several grits on one stick. go from the heaviest (only if you have horrible orange peel) to the lightest then (after the paint is fully cured) follow it up with some buffing compount (find it at your local automotive finish store) and wax,
I'm sure you have seen it a million times, but it is very useful in getting a much better outcome on your builds, look into the faq section and look at the painting threads.
did you use a primer? the paint may have crazed the plastic if you used plasticote automotive finishes, it's much to hot of a paint for plastic model aplications, unless you use a good primer. if you are using the plasticote craft paints, primer could be useful but not necessary. however following the directions on the side of the can usually turns out decent results.
start with several light coats, waiting half an hour or so between coats letting the paint dry a little. after you have some decent coverage, spray a couple heavier coats to get a smooth finish, let this dry for an hour or 3, then coat it with some clear using light coats, not necessarily mist coats, as you want this to be the shiney part, and need it to flow out a little. let this dry for about 3 weeks before applying any kind of wax, or polish, unless you run it through a dehydrator to cure the paint overnight.
I really hope this advice helps you out.
Old 12-24-2006, 10:09 PM
you know after taking a REALLY close look, I think that a good clear coat would be all you need to have a really great finish on this.
Old 12-25-2006, 07:48 AM
D.E D.E is offline
OK. I will remove all non red parts from the body and clear it. Thanks.
Old 12-25-2006, 05:35 PM
D.E D.E is offline
What is this, what does it look like and where can I find it?
