Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 09-01-2001, 12:20 PM
G202Go G202Go is offline
Unhappy My Tach is Dying
The tachometer in my 92 G20 is dying. The needles drops dead intermittently and usually within the first 15 minutes of driving. After a while it settles down and acts normal. I've check all the wiring to the tach: 12v Ignition, ECU signal and ground but I can't find anything loose/broken. When I head for the junkyard, my question is: Do I get a used instrument cluster or an ECU to solve this problem?
Old 09-01-2001, 12:38 PM
P10DET's Avatar
P10DET P10DET is offline
Re: My Tach is Dying
I had the very same problem with my first gen Scirocco. I pulled the dash apart and couldn't find any problems. As I was putting it back together I noticed a loose nut and tightened it down "just because." That took care of it. I would guess you have a loose connection somewhere. You might want to make sure all the screws that hold the printed circuit board are tight.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 09-02-2001, 09:10 PM
ky_infiniti2000's Avatar
ky_infiniti2000 ky_infiniti2000 is offline
Send a message via ICQ to ky_infiniti2000 Send a message via AIM to ky_infiniti2000
I am having the same problem...if u find the solution let me know...
Old 09-20-2001, 07:40 PM
HawaiiG20 HawaiiG20 is offline
My Tach is acting up too
Aloha from Honolulu:
I just bought a '92 G20 and love it. Hope it is trouble-free, as I just dumped a '93 VW Passat that was giving me headaches.
One minor problem on my G20 is the tach.
It does the opposite of what is happening to G202GO reprots. My tach's needle will suddenly jump way up, to the 5000 or 6000 RPM level.
Then it will drop back down suddenly. Or not. It sometimes "sticks" at the high level, even though the engine is revving around 2500 to 3500 rpm.
I assume that if the tach itself is bad, it is a lot of work to remove it? Any chance it could be a connector? Any suggestions as to places to check before pulling out the dash?
Mahalo! (thanks in Hawaiian)
Terry
Old 09-22-2001, 01:14 PM
It's worth taking the instrument cluster out and reseating the connectors. Your 96 should be easier than my 92 because I have to deal with the speedometer cable. I found it easier to remove the steering wheel first because it makes everything easier to reach. I've had mine out 3 times now just to do continuity checks on wires and to tighten screws but I still have a problem. I might just head to a junk yard soon and get a another instrument cluster. Don't forget to disconnect the battery before you start taking things apart.
Old 10-22-2001, 06:42 PM
After taking my instrument cluster in and out several times, checking wires, reseating connectors, tightening screws, I finally broke down and bought a used instrument cluster for my 92 from a junkyard. $75. I swapped out the speedometer to retain my original mileage. My tach works great now. I don't knoqw what caused my original to die but I'm back in business now.
1999 LeSabre - strange short-term fix for speedometer and tach that sometimes works Taurus1997 LeSabre 8 01-07-2011 01:29 PM
Engine stumbles, tach dies, stalling TopherS Park Avenue 5 01-23-2010 08:06 PM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
97 stratus, tach dies and odometer too tvguy1 Stratus 5 07-10-2006 07:19 PM
2001 GT-Trac off light comes on and tach dies corgiguy Grand Prix 3 11-11-2004 08:59 AM
