Old 12-19-2006, 08:12 PM
daklunk's Avatar
daklunk daklunk is offline
WIP: Lime green RSX
I really should be working on the Eclipse, but sometimes it's good to take a break and build something simple to get the juices flowing again, my juices have been kinda stagnent lately I keep getting hung up on minute little things that you won't be able to see when the build is completed anyway
Anyhow, I'm building Revell's excellent RSX kit pretty much OOB as to simplify things, no custom turbo set ups or wildly intricate engine detailing on this one. Minimal mods...
Here's the color I'm using, Tamiya light green because I looooooooove lime green I will be making custom masks based on the included tear graphics and spray them black, which should look really sweet. This is just a pic of the stock rear bumper I painted as a test, I'll be using the bodykit.
These are the wheels from the '93 Civic, the centers will be gloss black and the lip and hardware will be chrome/polished. Rotors will be aluminum metalizer, brass hubs, and black calipers.
The kit wing will be painted black with green caps and balck struts, I'll use black sponsor decals from, uh, somewhere, dunno yet, and I might paint that one section of the hood/front bumper gloss black. I would love to have some smoked Altezza style tails, but these lenses are solid red...
I didn't like the stock look kit of the steering wheel on such an eye-catching ride, and I had an extra Revell Eclipse steering wheel and column laying around, soooo...
Looks much better IMHO, It will be black and silver, I just might make that center button thing green just because, the only other green thing will be the palm patch on the shift knob.
The interior is flat black and two shades of primer gray, the carpet was sprayed a light primer which spat everywhere, which was good because it simulates the look of carpet better than the kit plastic. The remaining greys are darker primer, and the rest is flat black. I have yet to mask off certain parts of the doors, dash, center console, audio housing, and seats to be painted grey, black, or silver trim. Yes I know, the sub rings look awful, I did them with a half dry Sharpie Will redo...
That big empty package shelf was just begging to have some amps for the audio system installed. I'm using my own resin parts again, either 2 JL Audios (left) or 2 Kicker KX's (right). Both are shades of black, silver, and grey, so they'd go well with the rest of the interior. Or I could have the housing "custom painted" lime green just to be different...
Oh yeah, and the seats will be decked out with black 4 point belts and hardware. I might do a lime green iPod nano for the dash, that'd be cool
As much as I would like to go hog wild again with engine detailing, I must refrain *slaps own hand away from box of detailing wire* as I will refrain from adding any non-kit parts *busts ruler across knuckles as hand reaches for the resin stash*
This is the engine before detail painting, dry fit (nothing glued except for the the block and tranny) to the front subframe/cradle. Aluminum metalizer, Smoke wash, Tamiya green valve cover (the intake shroud will be the same color, but it's being stripped after I dropped it while wet). You can't really tell, but the green bled away from all the sharp edges
The first thing I noticed when I saw the engine on the box is that the conical air filter is right next to the exhaust manifold, not good for performance. Since I wasn't going to be doing alot, I decided not to build a heat shield (as one should) but to just chop the intake pipe a little. I drilled it out and added a rod to the filter, and now it sits a little further from the heat. But it's still not a very good situation...
I mixed some aluminum and some gold to get the brass color that I used to paint all the bolts. You can see (in order) the oil pan, the back of the engine, the front of the engine (painted wiring harness, water neck, and starter also) and the pulley assembly. I will be doing a second wash later tonight, and sometime later this week I should have more of the engine finished. opcorn:
Enjoy!
Slow down, dear, you're scaring the dog...
1:1 ride: '84 BMW 318i, needs attention. Stickin' with it
1:25 450+ hp DSM build, Click here for thread
Old 12-19-2006, 08:17 PM
ep-hatcher-510 ep-hatcher-510 is offline
Re: WIP: Lime green RSX
looks great! that kit dont look that bad at all, do u think u can provide a shot of the body? i been putting off buying one becuase it didint look as good when i saw the box picutres.
Old 12-19-2006, 09:08 PM
deltableh deltableh is offline
Send a message via ICQ to deltableh Send a message via AIM to deltableh Send a message via MSN to deltableh Send a message via Yahoo to deltableh Send a message via Skype™ to deltableh
Top notch work, man! The color looks great
Old 12-20-2006, 09:12 AM
andrew landon's Avatar
andrew landon andrew landon is offline
I actualy built one of these awhile ago and wasn't disapointed in anything exept for the brakes and the front window fit. i kind of want to redo the body as i really messed it up.
my name is andrew feel free to call me by it. and don't expect much from me.
Old 12-20-2006, 08:33 PM
NOMADGAMER NOMADGAMER is offline
SOHC cam gear :tup:
Old 12-20-2006, 10:32 PM
daklunk's Avatar
Thanks for the kind words guys!
hatcher, I will post up a body pic for you in my next update, I would suggest it anyway, it's a great kit, probably Revell's best tuner kit IMHO.
GAMER-- actually, K20s are DOHC, encased by the valve cover. The green "gear" is actually a pulley, I want to say P/S but RSXs don't have a conventional fluid-assisted P/S system, if I remember right...
Old 12-22-2006, 12:26 AM
sideshowscrappy sideshowscrappy is offline
Lookin good Dak. You gotta love that color. Looks a hell of a lot better then the model master sublime. The wash on the engine looks great too, Really adds to the realism............*Ryan*
Old 12-31-2006, 04:36 PM
daklunk's Avatar
OK, got a little progress here for you guys. My internet was giving me fits, so this could have been posted days ago...
Dry fitting of the mostly finished engine, still working on that intake cover. The valve cover details are semi gloss black, brake hubs are gold. Since this pic I have added more wash to the pulleys, repainted the brake hubs and top belt accessory (I still want to call it a P/S pump) Tamiya titanium gold, and used a little more wash here and there.
The engine bay was detail painted, just a few points are the steering rack, ABS unit, and master cylinder.
All together now! Still nothing glued yet, I'm going to wait until I know everything is completely ready to go together.
Before I weathered the chassis, I painted the major components that would be different colors (aluminum parts, the fuel pump, brakes lines, etc). I have the whole process on my photobucket as a walk through if anyone wants to see what I did.
Here's the chassis weathered, I was aiming for light weathering, not a huge build up of crud and road gunk.
An up close shot, I think I might add some rust here and there.
Here's the link to the chassis Photobucket, and the chassis weathering mini-write up:
http://s5.photobucket.com/albums/y19...20RSX/Chassis/
I might be able to get some more up later... Enjoy! opcorn:
Old 12-31-2006, 06:34 PM
rsxse240 rsxse240 is offline
for not doing any major work, I'd say that is just about as good as it gets. I hate hondas, but this is sensational
Old 12-31-2006, 06:51 PM
COBRA_427's Avatar
COBRA_427 COBRA_427 is offline
Here is my Lime Green RSX. I made this one in June 2006
JAJAJAJAJA
Good Luck with the hood!
Old 12-31-2006, 07:03 PM
psycho raven's Avatar
psycho raven psycho raven is offline
cobra that is a model top of the line, good job
Old 12-31-2006, 07:30 PM
daklunk's Avatar
@ rsxse240: Thanks bro Hate hondas, huh? What do the first 3 letters of your screen name spell LOL, j/k Hey BTW, I sent you a PM reply a while back, dunno if you got it? Lemme know...
Dude, Cobra, that looks tight! I thought about metallic lime, but decided on just straight green because of the compliment color, gloss black. It looks like you're using the same amps too I like it. I won't be using the CF on the hood, though, I'll be painting it...
Old 12-31-2006, 07:47 PM
daklunk the paint of your motor is in metalizer? is look good
Old 12-31-2006, 07:54 PM
daklunk's Avatar
Yeah, mostly everything aluminum is Metalizer. I love this stuff, it's all I use anymore. Great in the can or in a bottle, it says for airbrsuh only but I use it just the same on a brush. It's fantastic stuff.
Old 12-31-2006, 08:18 PM
i new on that, i have a revell enzo and all the motor is in magnesium. this is the first time i paint
