Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-20-2002, 12:41 AM
cnycivic cnycivic is offline
Send a message via AIM to cnycivic
what do i do first
ok .. i have a 2000 civic dx ... plan on doing a b16 swap .. yadda yadda ... thas not the point ... my question / questions are, what do i do first ... i have money to make this work i just need knowledge ... right now i have some cheap strut bars front and rear and some cheap coilovers (adjustable springs) what do i do .... i plan on gettin one piece coilovers and sway bars ... tie bars ... and mabye new strut bars ... also what tires are best ... i have falkens .. not sure of the model but i can check that out ... just didnt know if there was a certain best kind ... i also wanna know about weight distribution ... should i stick with a b16 or go bigger ... remember im not looken at alot of power i want handling ... so i figured the lighter engine would do me good ... also if i work the engine should i build it for high compression or look at a turbo ??? so what is your input ... i want to know brands, sizes, everything i need to know about cornering and how to put this all together ...!
Old 09-20-2002, 06:44 PM
Duatone Duatone is offline
stick with the b16..as for the b18 is costly more, and only for a little torque, if your oging to upgrade, either go directly for the kill and stuff in a B18c model, take your pick, or if you build up an ls-v-tec motor you can man-handle a b-16 easily. if you were to throw in a gsr crank, you'll keep a constant hp gain throughout the rpm's.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 09-21-2002, 02:27 AM
CustomWhips's Avatar
CustomWhips CustomWhips is offline
Send a message via AIM to CustomWhips
honestly
man. b 16 is all good but save some cash and suep your stock up ...
increased cylinders tougher larger pistons , ect
i went from i think stock dx 99 got like 115 hp
dude my stick got 180 motor sports tested it. look into it man...
tell em what you want they will give you a price mine was like 1100
stiff engine feels nice dude... get a loan lol...
Old 09-21-2002, 05:14 PM
obviously u didnt understand me ... thanks for the replys but i didnt ask about an engine i wanted to know about suspension ... doesnt anyone know !
Old 09-22-2002, 04:47 AM
curveball3110 curveball3110 is offline
my suspension input would be koni yellows and ground control coils - if you dont mind the slightly bouncier ride from the coils. use a skunk2 camber kit and the comptech tie bar / sway bar combo. a neuspeed front upper strut bar and yo're set. peace
Old 09-23-2002, 03:39 PM
am i better off buying one piece coils or buying struts and then adj springs ... which is going to be better if there is a diff ... and also is there a diff between cheap adj springs like say aerospeed or good ones like ground controll?
What First? 79_MonteCarlo Street Racing 5 08-06-2004 09:58 PM
My honda's chosen. Whats first step? IceWind Exterior | bodykits | Lighting 21 06-11-2003 11:55 AM
Whats first ...decals then wax?? VRDubb02 Car Modeling 6 02-27-2003 12:24 AM
Bodykits: what first, Paint or glue and putty..? Wishmaster Car Modeling 5 09-27-2002 08:23 PM
What First? 79_MonteCarlo Monte Carlo 0 07-29-2002 12:34 PM
