Looking for A/C Fuse & Relay Box
BTW, a member over at the SaturnFans site recommended this forum.
Very impressive on my first readings. I'm trying to trace down my wife's A/C issue with her 1997 Buick LeSabre Custom Touring car. This is a very rough estimate, as I cannot access my spreadsheet for the moment, but I believe that the car has 68,000 miles on it. My wife's car's A/C compressor is not coming on when she activates the system. I've found the fuse box under the dash, driver's left side, but cannot find the other fuse box. I've been told that there are two fuse boxes, in which each has an A/C fuse. I also cannot find the Relay for the compressor, for I feel that that may be where the issue rests. It goes without saying, your input is greatly appreciated.
1997 Buick LeSabre Limited, with Grand Touring Suspension (72,925 miles) with UIM/EGR Stovepipe leakage issues resolved/repaired & 1995 Saturn SL2 (498,125 miles) as of 6/19/07
Re: Looking for A/C Fuse & Relay Box
You may want to check the pressures of the refrigrant. When it gets low the unit will not come on.
You should find the fuse and the relays under the hood. Look for a black plastic cover. I have a '95 amd '02 so I am not sure about the '97. The '02 has fuse under the hood and fuse and battery is under the back seat. If you don't locate the trouble you can try this site: http://www.autoacforum.com/categories.cfm?catid=2 They are very helpful with ac problems but they are gonna ask you about the pressures |
I concur with Buckroo, about the refrigerant being low. If you have the ACC system, (Auto climate control) low refrigerant will cause the temperature display, to blink off/on for two minutes after the ignition is turned on, or after the car starts. (Either one) The blinking display is telling you about a fault in the system. Low Freon is a fault that will keep the compressor from engaging. The fuse under the dash powers the controller & display and the fuse under the hood is for the blower motor. If your display and fan are functional, you do not have a blown fuse! The compressor engage function originates at the controller with the selection of the AC function. The controller then sends a signal to a relay to energize the compressor clutch to run the compressor. If your controller has a “low Freon” fault, it will not command the compressor run relay to energize.
Knowledge can be communicated, but not wisdom! ![]() ![]() Last edited by HotZ28; 12-16-2006 at 05:30 PM. |
I should note, I'll take a closer look at the display window, when I get in the car tomorrow morning. But, as far as I remember, no blinking was noticed, however, I'll make a point of directing my attention to that screen tomorrow. BTW, your paragraph above was sooo appreciated, for it was in such detail, in terms of specific explanations of the various components. I truly appreciated it. >Buckaroo<Thank you for the A/C site, I'll follow up your suggestion.
![]() When you select the AC function (by pressing the AC button) on the controller. Note: The ambient temperature must be above 55 deg and the display temperature setting must be lower than the cabin temperature, in order for the controller to command the relay to energize. ![]() Quote:
10 or 110 - Ambient Temp Sensor circuit open or shorted. 13 or 113 - In-Vehicle Temp Sensor circuit open or shorted. 15 or 115 - LH Solar Sensor circuit open or shorted. 35 or 135 - Data Line failure - HVAC Control Assembly 38 or 138 - Data Line failure - PCM 40 or 140 - Driver Air Mix Motor circuit open or shorted, or not calibrated 48 or 148 - Long Term Freon Loss 52 or 152 - Keep Alive Memory lost; sets with battery disconnected 66 or 166 - Low Freon A number (1) prefix, indicates a history trouble code. Quote:
Knowledge can be communicated, but not wisdom! ![]() ![]() Last edited by HotZ28; 12-16-2006 at 07:53 PM. |
I thought with the R134a and odb-ii systems GM got rid of the low freon indication and respective DTCs in the ACC - Auto Climate Control systems?
One reason being is the refrigerant pressure switch is not just a low pressure switch but a high too. I've experienced no ACC DTCs or the climate control display flashing with a low refrigerant charge. However the charge was low and I had to add R134a refrigerant. The PCM module provides a reference signal of around 5 volts to the pressure switch and the switch provides a representative signal back to the PCM module letting the PCM know the charge is correct or at least within the low and high limits. Then the PCM module will send a low to the AC Clutch relay to engage the compressor. The ACC head unit provides AC REQUEST enable to the PCM module. This is a list of typical trouble codes displayed by ACC units from around 97 and up. This is from a CJ2 unit. Codes are accessed by taking ACC to diagnostics mode by pressing a combination of buttons on the ACC like AUTO and OFF at the same time. It may be different on this year/model LeSabre but the diagnostics mode which ACC units have now is covered in the GM FSM and can be done DIY by the owner. Position Description -00 Error codes -01 (servo position) 103-107 43-162 -02 (servo position) 128 120-202 -03 (servo position) 150 162-194 -04 CJ2 Fan Speed Low=15, 29, 44, 58, 71, 86, 110=High, CJ2 Unit will adjust to other increments as needed -05 (servo position) 93 88-191 -06 (servo position) -152 00-252 -07 (servo position) 00 0, 34-255 -08 (servo position) -155 00-255 -09 (servo position) 00 0, 23-255 -10 ? 04 04 -11 CJ2 Vent Mode 1=Def, 2=Bilevel, 3=Auto, 4=Lower, 5=Def+Lower -12 Engine Coolant Temp -60 degrees 80=104, 95=131, 100=140 Peak@135°F -13 Actual Vehicle Speed in MPH -14 (servo position) 00 21=0 -15 ? 39 44 -16 Radiator low fan turn on temp -106 207 -17 Radiator low fan turn off temp 196 199 -18 ? 50 51 -19 (servo position) 162-169 40-172 -20 Affected by cabin temp sensor 89 50-172 -21 (servo position) 00 ? -22 Sunload Sensor -117 LIGHT=126, 218=DARK A two digit code indicates a current fault while a three digit code indicates a historic fault. Trouble Code Description 00 No System Fault 01 or 101 Inside Air Temperature Sensor Short 02 or 102 Inside Air Temperature Sensor Open 03 or 103 Ambient Outside Temperature Sensor Short 04 or 104 Ambient Outside Temerature Sensor Open 05 or 105 LH Electric Actuator Open or Short 06 or 106 RH Electric Actuator Open or Short 07 or 107 UART Serial Data Line Fault 08 or 108 Solar Sensor Open
; however, I have never seen nor heard, of anyone being able to access the diagnostic mode in 94 up systems, without the use of a scanner. If you can find the information giving details on how to do it without a scanner, please post that procedure. That would be some great new information to have and would be worthy of a “sticky” thread. Thanks again for your support!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
I understand the temperature must be 55+, with the display temperature setting being lower than the cabin temperature. But something tells me that when you refer to the "controller", you do not mean the display setting, but mean an actual component, called a "controller". ?? As to the diagnostic feature of the system, and fully understand that one needs a On-Board Diagnostic 2 (OBD-11) reader/scanner, but, I return to the "blinking display" light, at the time of initial ignition start up. I'll be checking that in about an hour. Quote:
I'm also assuming, that should a ACC DTC (( Auto Climate Control system Diagnostic Trouble Code )) be 'set', that an initial alert would be the flashing dash panel, upon initial engine startup. Quote:
This truly has been very informative. I'll report back. Thank you, Luke
Follow-Up
Well, yesterday, when I started the car, there was no flashing on the ACC display; The 'outside' temperatue remained constant. I should also note, that there also was no reaction when I pressed the Auto and Off buttons, simultaneiously. Display continued to present the outside temperature >57 degrees <
A friend has an OBD-II scanner, so I'll be borrowing it. I'm assuming that the it is to be inserted into a DLC >Data Link Connector< under the dash, driver's side. >Atleast that is where the DLC is located on my Saturn. < Quote:
I borrowed a "Innova #3100 Digital OBDII code reader" (((>and of course, it's owner's manual <))) and will be using it this weekend. In addition to 'generic' codes covering A/C refrigerant pressure issues & A/C Clutch relay control circuit -high/low- issues, it also covers General Motors specific codes.
With all that said, one would think, that the failure of the compressor engaging, a code would have been set. Oh well, will report back.
The relays in the center are often the same number so they can be interchanged. You might try that after the clutch check on the compressor. I'll look for the fuses again (I forgot what I found) and post. I find fuse Auto A/C Cruise Fuse 5A Fuse 9C for MSC/RDO/CLSTR looks like keep alive it's hot all the time. The number is the column and the letter is the row if I recall correctly And I find a fuse 7E 10A called Non OBD II MISC ENG and it powers the clutch relay!!!! I assume all three of these are in the fuse block by driver's left knee. There is another fuse block above the passenger foot inside the hush panel is a picture showing which fuses and relays are there. The panel is on the A pillar area under the dash to the right of the glovebox. I just checked my hush panel since it's off and in the trunk-there's a fuse For Non OBD II MISC Eng on that panel against the right side. It looks like there are two or more vertical columns of fuses on my 1998 and the top one second from the front of car is the Non OBD II MISC ENG. Note all three of these fuse are listed as IP Fuse block. I guess they just don't say which fuse block in the service manual. And the fuse is not 7E in the main IP panel next tot he driver! That may be the fuse you're looking for!!! It powers the relay pull in circuit when grounded by the PCM and it supplies thepower for the relay to connect to the clutch to ground and engage the clutch. Good luck. (Just checked owners manual in car and it shows a 7E under the driver's side as Non OBD II Engine controls. I didn't check the actual panel since the car's in the garage and I like to crawl upside down under the dash with it outdoors to have room. Last edited by imidazol97; 12-19-2006 at 08:57 PM. |
>Hot Z< Wow, super site, thank you....
I'll also be checking fuse # 7E. Thank you....
Atleast this give me information when I check the actual fuse box. Quote:
