| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Voltage drop ok?
On my 81 VW Vanagon, with engine running, voltage across battery is 13.9 volts. When I turn on all accessories, voltage drops to 13 volts. Is this an acceptable drop?
Thomas |
Re: Voltage drop ok?
yep, sounds good to me. as long as it doesnt hang below 12.6 volts you arent in discharge condition. 2.1V per cell, 6 cells in your battery
Agreed. that's fine.
Dragging people kicking and screaming into the enlightenment. |
Hmmm, The voltage is right. What amps do you need? Why are you measuring the voltage? Is there a problem with the electrical system?
EMS Motto: Your Misery is OUR Pleasure |
Because voltage is an accurate measure of the state of charging. You can't practiaclly measure amps without cables the size of your thumb.
life begins at 10psi of boost Three turbo'd motorcycles and counting.
Very true, but finding one that does DC amps is costly and difficult. Even then, it won't tell you anything about the charging system. The amount of amps moving through the wire could be anything up to the alternator's rated capacity. If you see 10amps, it doesn't tell you anything without knowing voltage.
Most inductive clamp meters still function as a normal multimeter, so you could use the same meter to measure voltage
If you find one, let me know
The last one I found was $538.
I'm repeating myself, but sears, under $100. Its sitting in my tool box at work.
For example, sluggish starting with the batteries dropping to 16v (24v starting). Could be the batteries. Throw the clampmeter around the earth lead, hit the starter and find it recorded 511 amps. ![]() Instantly showing that batteries, connections and wires area ll good. Clean out the starter and it drops to 130amps. A knowledge of ohms law with a clampmeter will let you know exactly what's going on. Most items you deal with in a vehicle are fixed resistance. |
[quote=bm2boats]Hmmm, The voltage is right. What amps do you need? Why are you measuring the voltage? Is there a problem with the electrical system?[/quot
My battery kept dying, I would run my va once a week just to charge the bat. I thought it was the alternator being bad but after replacing the bat, its all good. |
