Old 12-09-2006, 09:35 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
2004 Dodge
I have a 2004 diesel dodge ram with a Cummings turbo diesel. Yesterday I was driving down the highway at about 75mph and all of a sudden, it coughed out a puff of black smoke, lost RPM, and died. I coasted to a exit ramp sat for a minute and tried to start it again it fired and died after a few seconds. It did this about six or seven times, then started, and ran fine. It is about 20 degrees here so I thought that maybe I was getting some gelling so I went to a truck stop and bought a bottle of antigel. I proceeded down the road and it happened again although it only took about three or four times to start. Does this sound like a fuel gel problem or is it something else? It has not happened again since but I am just a bit worried I may have caused damage to my injector pump and other componets.
Update today it was running ruff so i got on it a bit it the spit sputtered and died. Left me a foot. From what i have read it sounds like it may be the lift pump. Anyone know anything about this?
Old 12-10-2006, 07:54 PM
englishman englishman is offline
Re: 2004 Dodge
does your dodge have a water trap in the fuel filter? if there's any water in there at 20f this could freeze and stop the fuel flowing, by stopping, the heat of the engine might thaw it out just enough to let it run again. Most fuel filters have a water drain, try opening it to let any water out.
Old 12-10-2006, 08:58 PM
Austin8214's Avatar
Re: 2004 Dodge
No there is now water in the filter bowl. it was also much warmer today when it died.(40f)
Old 12-10-2006, 10:42 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: 2004 Dodge
Is the filter due for replacing? It could be the lift pump and if it is, don't run it until its fixed. You can damage other parts if you do.
Dragging people kicking and screaming into the enlightenment.
Old 12-11-2006, 01:16 AM
KiwiBacon KiwiBacon is offline
Re: 2004 Dodge
Definitely sounds like a fuel delivery problem.
It could be a fuel blockage or it could be air intrusion. It could also take a long time to find.
Old 12-11-2006, 05:26 AM
Austin8214's Avatar
Re: 2004 Dodge
No, I had the filter changed about 6,000 miles ago. Anyway, I pulled the filter and bumped the starter to engage the lift pump and the filter bowl did not fill up so I am guessing it is the lift pump. I hope that it is still under warranty.
Old 12-13-2006, 11:02 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 2004 Dodge
You may want to start a similar thread in the Dodge Truck section.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
