Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-07-2006, 04:51 PM
Dr. Doom Dr. Doom is offline
Question about 245/35/20 tires
I'm going with 20'' rims and I already bought the tires which are 245/35/20 low profile tires but I needed to know if I cn fit a 7.5'' rim on that tire? Also I have another question. The tires are tubeless radials so do ever require air at all?
You will never get ahead trying to get even.
Old 12-07-2006, 08:36 PM
RightWingZionist's Avatar
RightWingZionist RightWingZionist is offline
Re: Question about 245/35/20 tires
Aint all tires tubeless? It's not a bicycle tire right. You need to pump it with air relative to the max psi it has and the weight goin on the tires.
Old 12-08-2006, 05:09 AM
Yeah I just found out all car tires are tubeless. Do you know about the 7.5'' rim fitting though?
Old 12-08-2006, 10:05 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Go to the tire manufacturer's website (or any tire website including Tire Rack). They list acceptable rim widths for every tire they sell. Just click on "specs" and all the possible tech on that tire will be listed.
Dragging people kicking and screaming into the enlightenment.
Old 12-08-2006, 05:26 PM
CapriRacer CapriRacer is offline
I hate to do this but I suspect you've got more problems than the rim - which BTW isn't wide enough for the tires.
Could you supply us with the vehicle these tires are destined for?
