Old 12-06-2006, 08:58 AM
Candlechic15's Avatar
Candlechic15 Candlechic15 is offline
Hearing wind & outside air on 4dr Grandam passenger door>rear*
On my 03 grandam Gt 2003- I have always heard while driving over 35mph - a slight wind/air coming in on the right rear passenger door area- near where the molding - strip would be to seal the door while closed.
I had it serviced once in 04 for it never again because theys aid all is GOOD-
I still hear it specially ' on the freeway!
anyone else have advice? am I crazy ?LOL
Heather ann!
Old 12-06-2006, 10:27 PM
caddyman379 caddyman379 is offline
Re: Hearing wind & outside air on 4dr Grandam passenger door>rear*
Don't be offended but, is the door closed all the way? Has the vehicle had an accident near the door frame or the striker bolt? I would inspect the seal around the door to see if its severely cracked or loose. If it's an 03 its still under warranty right? I'd take it back and see if one of the service managers would drive in it with you.
Old 12-07-2006, 08:13 AM
> yes lol the door is closed, cmon Im a woman IM not a dingbat!
I use to race cars back in High school & college- circle track & drag.
not that nutso dear! lol...but to answer the rest of the q's...
no accidents at all thank the lord & the bolt is completely in tact.
the dealer said the seal is fine! twice now+ not under original warranty no , esp plan I have ext'd yes-- so! I wont get it fixed just to ease sanity, deductable is 100$ so I will have to see what else can be done.
I have done the drive around thing ,,,doesnt work it seems lol
Heather ann!
Old 12-07-2006, 09:08 AM
BNaylor's Avatar
BNaylor BNaylor is offline
It is a common problem on GM N body cars like the Grand Am and Alero. The door seals are subject to premature wear and IMO poor quality. The air rushing sound or any rattling sound like the door being loose gets worse in the colder months. Check the door alignment from the outside in relationship to the body. Gently push in around the back of the door by the handle and see if you feel any slop as you push inward. You can make an adjustment on the door latching assembly. At the doorframe is a latch/striker plate that can be adjusted to give the door a better seal. There are two Torx T40 bolts you can loosen and then move the plate inwards. It will also adjust upwards/downwards/outwards. So do it carefully and in small increments until the door feels tight but without affecting overall alignment with the body and door latching/release. Before making any adjustment scribe the plate with a pencil or marker so you will be able to get it back to the original position just in case.
Timeslip 08/12/06
AF Community Guidelines
Old 12-07-2006, 09:48 AM
Post Re: Hearing wind & outside air on 4dr Grandam passenger door>rear*
its nothing of the above , as due to t he "noise " I am hearing.
sorry to say its not that serious- just that it may need new foam
around the door jams- but thanks for the insight--- its just not that complicated & nothing is rattling! just wind being heard while on the freeway or going over 35-
Heather ann!
Old 12-08-2006, 07:34 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
My SE and GT did the same on the rear pass door.
I used a sheet of paper to find the loose spots along the gaskets, my gaskets are like new.
I did what Bnaylor suggested, moved the door strike plate to tighten the door seal a little.
It fixed the SE but the GT, I believe, is leaking air from somewhere else
Most Body shops stuff a putty/waxy stuff under the seals to raise them enough to seal the leak(s) when moving the latch or striker doesnt work. Just my
Good Luck
1999 Grand Am SS 3.4 OHV
