Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-05-2006, 10:02 AM
2003imp 2003imp is offline
2003 ipmala supercharged
I Have An 03 Impala And I Have A Supercharger From A Grand Prix With Injectors I Wanted To Know What Else Would I Need To Complete This Mod.
Old 12-05-2006, 11:03 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2003 ipmala supercharged
Welcome to AF.
You'll need more than just the Eaton M90 supercharger and L67 fuel injectors to do a successful L36 to L67 swap. ZZPerformance has a L36 SS M90 install kit for the Impala which is the best and most inexpensive route.
http://www.zzperformance.com/grand_p...ts1.php?id=382
If you decide not to use the SS M90 kit and the supporting parts mentioned in the link above then you will need the L67 lower intake manifold, fuel rails and cylinder heads. A re-programmed PCM module, wiring harness mods for the boost bypass valve and a drive belt/tensioner/pulley system. Also, a higher volume fuel pump. Plus a bunch of other stuff.
Timeslip 08/12/06
AF Community Guidelines
Old 12-05-2006, 04:53 PM
Bnaylor I Wanted To Know If Everything You Suggested Is Needed If I Have The 3.8l
Old 12-05-2006, 05:03 PM
BNaylor's Avatar
The GTP has a L67 engine which is the supercharged Series II 3800. Your Impala has the Series II 3800 normally aspirated aka L36. Everything mentioned will be needed to mount the Eaton M90 blower you have off that GTP. The M90 blower will not fit your current lower intake manifold. Also, the L67 heads will be needed because the fuel injectors are mounted at the cylinder heads not the lower intake manifold runners like yours. The swap has been done successfully by others but without using the ZZP SS M90 kit to include their specially machined lower intake manifold it will be expensive and very tedious work.
Timeslip 08/12/06
Old 12-05-2006, 05:50 PM
Thanks
